Hey everyone, I have a question
Old Jul 14, 2009 | 11:12 PM
n_kempin's Avatar
New User
Default Hey everyone, I have a question
Hi,
Im new here, and I need some help. I am looking at buying this 1995 Integra Gsr with a B20 swap. Now heres the problem.. When can you tell if its too late to adjust the valves, because they're already messed up? The car im looking at seems to make a ticking noise coming from them and its pretty loud, the car runs great otherwise with only 65.000 miles. <---Is it a big deal? "If it is, how much is it to get a b16 head and make a b20/vtec with it?
Sorry if this is in the wrong place...
Thanks
Old Jul 15, 2009 | 12:08 AM
stevenDAtegra's Avatar
Default Re: Hey everyone, I have a question
Have you ever had a DOHC honda before? The valves are notorious to sound pretty loud, even when things are fine. Unless it gets loud when you rev it up and you hear a lot more clicking than other ambient sounds, it's probably fine
Old Jul 15, 2009 | 12:14 AM
n_kempin's Avatar
New User
Ok, thank you Steven, I was just curious and its pretty loud that's all.
Old Jul 15, 2009 | 12:22 AM
Yeah, no problem and welcome to honda-tech! If you go to look at it again, just give it a few revs. If something is messed up, it'd make a lot more noise once the revs go up.
The b16 head route will yield good results but if you want it to be as reliable as other motors, you may have to upgrade the rod bolts. I know LS B18 motors have weak rod bolts but not too sure about b20 rod bolts.
I spent around 2k on mine but got high compression pistons, did some security things for the block like rod bolts and balancing the roating assembly along with a b16 tranny.
Old Jul 15, 2009 | 12:56 AM
Ruben19's Avatar
my b16 head with blox type b cams is pretty loud even with blox/factory specs.
Old Jul 15, 2009 | 06:35 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Tarmac Junkie
Apr 19, 2012 12:04 PM
fkncivic
Jul 25, 2008 12:08 PM
VeeL_B20
Jan 13, 2008 07:23 PM
t3hatch
Sep 23, 2005 12:33 PM
Trungsta
Sep 29, 2004 11:00 PM
