b20 vtec valvetrain noise
Old Oct 22, 2006 | 10:15 AM
Tarmac Junkie's Avatar
Default b20 vtec valvetrain noise
I recently put new type r LMA's in my stock b16a head because they were bad. Now the motor makes a clicking sound, but everything went back together the same way I took it off. The valve adjustment I used was for a gsr and type r, out of the hanes manual .007 intake, .008 exhaust. Any ideas? Do you need to run different clearances on a b20 vtec? I'm also running 11.5:1 pistons.This same noise is why i replaced the LMA's in the first place. Thanks for any help...
Old Oct 22, 2006 | 12:42 PM
Default Re: b20 vtec valvetrain noise (Tarmac Junkie)
Old Oct 22, 2006 | 06:29 PM
No ideas????
Old Oct 23, 2006 | 05:57 PM
help help help
Old Oct 23, 2006 | 05:59 PM
FaceTuned's Avatar
if its making a clicking sound its lma's or valve's need to be adjusted correctly.
Old Oct 23, 2006 | 07:57 PM
Default Re: (FaceTuned)
Do you know what to adjust them to? Right now there adjusted like a type r. Do you know if b20 vtec is different? In.007 Ex.008???
Old Oct 23, 2006 | 08:09 PM
SirRevvs's Avatar
Default Re: (Tarmac Junkie)
Did you prime the LMA's? Is a random ticking or a consistant ticking?
Old Oct 23, 2006 | 08:28 PM
j spec's Avatar
Default Re: (SirRevvs)
clearances/tolerances are the same
Old Oct 23, 2006 | 10:16 PM
what do you mean by prime them? I spun the motor (no plugs) to get oil pres. before I started it . And its a constant ticking 2400-3700rpm's then the motor is too loud too hear, but I think it probably still makes the noise. The motor run fine though, but clicks????
Old Oct 24, 2006 | 12:28 PM
FaceTuned's Avatar
he means soak the lma's in oil. just adjust the valves like a b16 -.7,.8 int, i dont remember off the top of my head but if you adjust them perfect and that dont fix it then change the lma's
Old Oct 24, 2006 | 07:20 PM
I did soak them in oil for about a day and a half. The new LMA's only have 300 miles on them, and its been making the sound since start up. The LMA's were brand new from honda.
Old Oct 25, 2006 | 05:18 PM
any other ideas?
Old Oct 25, 2006 | 05:26 PM
N1 Andy's Avatar
R.I.P. Andy
11.5:1? im assuming you have forged pistons, could it be piston slap you are hearing? damn, new lma from honda must have been a pretty penny
Old Oct 25, 2006 | 07:00 PM
Default Re: (Slow Jdm EG6)
It might be piston slap, but I don't know what would cause it. It came out of nowhere, and yes 8 honda LMA's were not cheep.. Still confused.
I dident change the cam timing or anything like that???
Old Oct 26, 2006 | 09:40 PM
Old Oct 26, 2006 | 09:54 PM
FaceTuned's Avatar
do a compression test to see if the valves did hit you know if your loosen compr, and did you try to adjust the valves? take the v.c off and check and see if there loose.
lmk
Old Oct 28, 2006 | 05:05 AM
Ill recheck that stuff, but it was all good last time I checked. Over 200psi comp. and valves adjusted perfect.
Old Oct 29, 2006 | 07:50 AM
FaceTuned's Avatar
11.5.1 should be atleast 240 psi in each cylinder
Old Oct 29, 2006 | 10:19 AM
My comp. checker only goes up to 200 psi, and it goes past that but i'm not sure what to exactly.
Old Oct 30, 2006 | 03:08 PM
Danny_EJ's Avatar
well.. i do .006 intake and .007 exhaust. Then once I am done I turn the motor over twice and double check alot of times it changes a few thousands and I have to re adjust them and check again. I suggest you check the clearances again
Old Oct 30, 2006 | 04:31 PM
Default Re: (Danny_EJ)
I'll give it a shot. Thanks
Old Nov 1, 2006 | 05:32 PM
Valve adjustment is still perfect. Confused and lost????
Old Apr 19, 2012 | 11:41 AM
still_b_series's Avatar
change your oil
Old Apr 19, 2012 | 12:04 PM
billyb18's Avatar
change your oil and check clearance
jdm_sir2
22
Aug 31, 2009 08:30 PM
n_kempin
Jul 15, 2009 06:35 AM
hbboostman
Jun 11, 2007 04:03 PM
t3hatch
Sep 23, 2005 12:33 PM
