catalytic converter delete
Old Jul 14, 2009 | 05:50 PM
chacabaca's Avatar
Icon2 catalytic converter delete
i just purchased a set of dc racing headers, it deletes the catalytic converter. before i install it i wanna know if deleting the cat converter will trip any engine lights?
Old Jul 14, 2009 | 06:15 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: catalytic converter delete
It can yes. It will trip the 2nd o2 sensor. You can buy a spacer for the sensor to fool it
Old Jul 14, 2009 | 07:15 PM
kobeballer96's Avatar
yeah i was gonna do this to a while back but u need motor mounts or a stiffy and i herd from alot of ppl the psacer doesnt really work it throws a code after like 4k miles of drivin
Old Jul 15, 2009 | 05:17 AM
josh's ep3's Avatar
Function > Form
You don't have to have MM, or a stiffy but that would be a good idea, as well as cutting the hanger on the header. The defouler isn't guaranteed but it's an option. The better option would be to get K-Pro (if $ is not a factor), you would get the most out of the modification as well as no CEL's, etc...
Old Jul 15, 2009 | 07:33 PM
chacabaca's Avatar
Icon2 Re: catalytic converter delete
where could i get a spacer from?
Old Jul 15, 2009 | 07:59 PM
nahonda04's Avatar
Surje.motorsports
its actually called a defouler as josh mentioned, you can find it at clubrsx or clubep3, Strup makes them
Old Jul 15, 2009 | 08:22 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I also recommend not installing the hanger if you get a DCRH or etc.
They tend to crack there. You don't need it anyways just cut it off. This will help without having mounts or a stiffy
Old Jul 15, 2009 | 09:36 PM
tweek_boii's Avatar
get motor mount inserts. they are just under 30$ shipped, about anywhere..
no stiff motor :
Old Jul 16, 2009 | 03:00 AM
Gtimportfanatic's Avatar
defoulers can be made also... i made mine with 5 dollars worth of parts from auto zone... the part is a spark plug non fouler, u want the one that says 18mm or something.. either way i think its the biggest one they sell.. the processs is then to drill a hole in one of them because u get 2 in the package.. drill a hole so the 02 sensor can fit thru it and the connect both foulers together with the drilled one on the 02 and then the second one on the drilled piece.. and thats your home made defouler.. i've had mine on for about 250 miles now and no issues.. normally the light trips after 50 miles
Old Jul 16, 2009 | 12:00 PM
no stiff motor :
haha i seen this pic so many times
Old Jul 17, 2009 | 06:15 PM
tweek_boii's Avatar
I bought them and i was so mad the sensor didn't fit !!!! wow thank you !!
Old Aug 3, 2009 | 04:30 PM
tweek_boii's Avatar
Both of them didn't fit on my rsx, there was just no way.. I just used one, & reseted my ECU. I'll see how long that lasts with out the damn check engine coming back on.
Old Aug 4, 2009 | 05:41 PM
tweek_boii's Avatar
Just came on again, im getting the angled on from clubrsx
92eghb
12
Feb 27, 2009 08:32 AM
Slammed_am
May 10, 2006 02:35 AM
srehmat02
Oct 29, 2004 01:32 PM
fastitr01
May 17, 2004 03:56 PM
