HELP!!H22 Turbo CRX Overheating
Old Jul 14, 2009 | 04:14 PM
ksh's Avatar
ksh
New User
Default HELP!!H22 Turbo CRX Overheating
I've tried new thermastat, new water pump, new aluminum radiator, also tried pulling out thermastat but still over heats. Motor just been fully built at local machine shop. Before motor was built it never over heated, but since rebuilt temp. has been going to 208 while cruising on highway.
set up
67 turbo
pro turbo manifold
skunk2 intake manie
75mm mustang t.b
3 in down pipe
eg fluidyne rad.
12in fan
pics. coming soon
Old Jul 14, 2009 | 04:37 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: HELP!!H22 Turbo CRX Overheating
OK... Did you get the car tuned?
Old Jul 14, 2009 | 05:38 PM
ksh's Avatar
ksh
New User
my home boy from nori built started to tune it but about ten min. into it the temp starts to cimbe and recomended to get a biger fan so i did and it still gos up to 208. so for now it it only tuned so i can get to work and back. also its been perty hot here in texas about 100 deg. is it normal for it to get that hot? idk maybe timming?
Old Jul 18, 2009 | 10:46 AM
colocho19's Avatar
Im not an expert but let me try and help you... first of all is it just the block that was built or the head too??? because im thinking if the head was not built and not even taken it to a machine shop to have it look at before you put it back on your block then im thinking that the head might be warped!!! Is the head gasket new or is it the same one??? Is there white smoke coming from anywhere the motor in the engine bay???
Heres other thing:
***Check if the fan spins if its getting power???
***Check if you dont have air inside the block from the radiator???
***check the oil preasure
Old Jul 18, 2009 | 06:08 PM
lexusman83's Avatar
have you already tried to bleed the system, maybe a air bubble floating around. keep us posted (gl)
Old Jul 18, 2009 | 09:38 PM
Blaze45's Avatar
Brrraaaap!
When you say over heat, do you mean that 208 is overheating? The fan on most Hondas does not even kick on until 210. Are you doing most of the driving on the freeway? I always struggled to keep my water temp. down on the freeway, although I never dyno tuned my setup and I was running a half dual core rad. that blocked by my intercooler. Is your intercooler blocking most of your radiator? If so, this is will contribute a large part to your car overheating because air cannot take the heat away from the radiator. Please tune your car before you lose what you have spent on your car.
- Was there any work done on the head at all?
Old Jul 19, 2009 | 02:36 AM
project dc2's Avatar
what kind of fan ? pusher or puller ? fan shroud ?
Old Jul 19, 2009 | 05:37 PM
SIXTY-1HATCH's Avatar
it could be a # of things. Try running 90/10 mix, 90% being water. Not enough timing can do that sometimes, I have seen it before. I have been having problems with my hatch running hot too on hot days. Tryed EVERYTHING, then I noticed that If I take my bumper off the car, It would NEVER overheat. Ordered a SPAL fan, puller, and welded a shroud for it, and problem solved!!! Def. start with the obvious though, and make sure you bleed your system really good. If that doesn't work, try taking off your bumper and see what that does. If it helps, there ya go, it's a flow issue. I never thought of the fan not being strong enough, but man it makes a WORLD of a diff., I'm talking like a 10-20 degree drop!!!
Old Jul 19, 2009 | 07:06 PM
civickiller's Avatar
electric water pump. he has a meizer on his car and his car barely gets above C. he also drilled a hole in his thermostat
Evoknight10
Aug 3, 2015 10:39 AM
shanemcpie
10
Oct 6, 2014 07:43 AM
proda9driver
Sep 27, 2011 11:24 PM
ERKK
11
Jul 26, 2008 09:51 PM
CrxSiR-GNY
Aug 8, 2007 08:59 PM
