noise coming from engine... help
i have a noise coming from my d15z6 mini me. i am not sure if it is spark knock or a slight rod knock. it basically sounds like a exhaust manifold leak but its not. dosnt go up with rpm just happens when under load at low rpm. thanks
yea i tried using like a hose to see if that would work but it failed. i couldnt really hear it near the oil pan when i was checking the exhaust but i want to be sure. i'll pick one up tomorrow. thanks
well i have a 10:1 cr so i've been told to use 93. but i used to get by with 89. but also my rings were fried so i replaced my rings and i got the rattle noise so i wasnt sure if it was rod knock or spark knock. and i have a timing gun but no timing marks on my crank pulley its aftermarket. but either way if i needed to i could just retard it and let it run like ****
eortizr
Aug 12, 2005 01:44 AM
