Questions about swapping a replacement Y8 engine and P2P ecu into a 96 Civic EX
Old Jul 13, 2009 | 10:58 PM
DSM95AWD's Avatar
New User
Default Questions about swapping a replacement Y8 engine and P2P ecu into a 96 Civic EX
First off this is my first post, and this will be my first time working on a honda. I am an avid DSM guy, but my buddies DD took a terd. He was desperate and impatient and just bough on a whim a D16Y8 Engine for 400 dollars and a P2P A01 ecu for 40. His car is a 96 civic EX. I plan on helping him do this swap and am wondering what all is necessary. Thanx for any help.
Old Jul 13, 2009 | 11:18 PM
Ruben19's Avatar
Default Re: Y8 P2P ecu 96 EX
well, since you have the motor down. change your timing belt & water pump as well. everything else is a direct swap
Old Jul 14, 2009 | 03:07 AM
DSM95AWD's Avatar
New User
I wont have a problem with the ecu? Im sure going from non v-tec to v-tec something will have to be different with ecu/wiring?
Old Jul 14, 2009 | 07:41 AM
JShull's Avatar
If he has an EX it already had a Y8 in it. You should be able to just swap the block in and be good to go.
Old Jul 14, 2009 | 09:37 AM
gamerguyTHXtss's Avatar
New User
Yes I already have a 96 Ex. As you said it should already have a D16 Vtec in it. Thing is when I bought it, it didn't. Something is ****ed up here but I don't know what.
Old Jul 14, 2009 | 07:43 PM
JShull's Avatar
What engine did it come with?
Check where the solenoid would be. Do you have any extra plugs chilling there. (Check for the VTEC plug, you may not have to wire in the stuff for vtec if its there.
Old Jul 15, 2009 | 07:49 AM
DSM95AWD's Avatar
New User
After checking it out, my old engine was a B16y8, wiered thing is it says no where on the engine or car its a vtec, and my insurance card says its a civic AuX.
Old Jul 16, 2009 | 02:53 AM
boost SOHC's Avatar
something sounds funny there
Old Jul 18, 2009 | 06:51 AM
JShull's Avatar
The valve covers on the Y8s never had "vtec" on them they just said "Honda" and were the same on the Y7. My EX didn't have anything that said vtec either but it was pretty easy to tell I had a y8 with the stamp on the engine, solenoid, and the intake manifold.
Since it has a D16y8 in it already you won't have to do any wiring and there is a very good chance you won't even have to change the ecu. Swap can be done in 4 hours or so. Good luck!
Old Aug 28, 2009 | 03:10 PM
HondaSPEC99's Avatar
Hey I have a 99 civic Ex MT and its got the P2P Vtec ECU. I put a Skunk2 Intake manifold plus a 68mm TB on the stock D16y8 motor its got (4-2-1 DCS header, Full Skunk2 Exhuast sys, AEM short ram intake) and thats about it. Will the intake and TB hurt anything in my motor or make my car through codes?????
What size injectors would be pref for my civic D16y8 with the S2 manny and 68mm TB?
Is my ECU fine with all that (P2P Vtec ECU)?
Old Mar 12, 2014 | 05:10 AM
PistolCtyVa's Avatar
I kno this is old but what was stamped on the intake,solenoid to show you its a y8
Old Mar 12, 2014 | 05:46 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Don't bump old threads, start a new one instead.
Old Mar 12, 2014 | 07:14 AM
Former User's Avatar
Old thread closed.
Old Mar 12, 2014 | 07:16 AM
Post these questions in your current thread.
hondah
12
Jun 14, 2019 08:16 PM
dumpstering
Jul 3, 2012 09:44 AM
SouthernComfort
14
Apr 26, 2007 01:24 AM
