2000 d16y8 in 1990 ef HELP plz!!!!
Old Jul 13, 2009 | 12:21 PM
basktb1188's Avatar
Icon6 2000 d16y8 in 1990 ef HELP plz!!!!
ok... i have a 1990 honda civic EX... i want to swap a 2000 d16y8 motor in it...
i need to know what all i need can i use my d16a6 ecu? driveshaft? tranny the same and will it bolt up? will the dizzy work with it?
im not worried about Vtec because its a cheap DD for my girlfriend...
i need help wth it befor sink money in it..
thanks
Old Jul 13, 2009 | 12:33 PM
ek-g6's Avatar
Default Re: 2000 d16y8 in 1990 ef HELP plz!!!!
the ecu will work, but not sure if it will run right tho. Tranny and axles, and dizzy will work. my friend has d16y7 in his, and used all of his obd0 components.
Old Jul 13, 2009 | 12:36 PM
basktb1188's Avatar
as long as i can get it to run good im happy... what im worried about is all the obd-o parts with a obd-2 motor like the CPS and maf on the TB.. or do i swap the intake from the a6 on to the y8 will that work?
Old Jul 13, 2009 | 01:07 PM
ek-g6's Avatar
i would swap if you just want to get it running. if you want a bit more power sticck with ther y8 mani, but you will need somewhere to place the iat sensor. CPS wont be plugged in, and there wont be any problem if it isnt. I would change out the tb to your obd0, cuz it would be easier.
Old Jul 13, 2009 | 02:02 PM
4drEF's Avatar
Keyboard Humorist
Without the second set of lobes on the cam that engine isn't going to run that great especially if she ever gets on the highway.
Fuel maps are going to be all wrong with your stock ECU.
Seriously consider chipping and 1 wire vtec.
(Is your EX manual or auto??)
Stock tranny will bolt right up so no worries on the the tranny nor the driveshafts.
Your stock distributor will bolt right up to the Y8 head so staying OBD-0 is easy.
Not sure if the A6 distributor will bolt up to the Y8 IM, but it would be better for your idle if you can get it on there. You can use the Y8 TB as well, but will most likely need to adjust the idle screw to get the RPM high enough.
If you use the Y8 IM then flip the throttle cable bracket over to get the cable to fit decently.
Old Jul 13, 2009 | 04:09 PM
black0hatch's Avatar
also make sure your y8 intake isnt off an auto if your gona use it. the a6 dizzy might not bolt up to the y8 without trimming the ears. i had an a6 dizzy on a d15b vtec and i had to trim the ears but i ran it all obd0 without vtec for a while no problems.
Old Jul 13, 2009 | 05:05 PM
basktb1188's Avatar
you say the lopes will make the car run like ****? is there anyway around that?? or should i just sell the d16y8 and buy a nother d16a6? she just needs a good DD for work a bout 60 miles a day...hell i only paid 300$ for the car thats super clean(old lady owned) 251,133 miles on the body with no rust and i got the motor from a buddy that told me if i pull it and give him 50$ bucks its mine.. so i did..
oh and its a auto d16y8
Old Jul 13, 2009 | 05:23 PM
SPIKE'S91CIVICSI's Avatar
i jus did a y8 swap on my 91 civic nd it worked jus fine.i used the stock manny,dizzy,tranny,axels, and ecu.
Old Jul 13, 2009 | 05:44 PM
ONEFASTJDM's Avatar
this motor is a fairly easy swap. once its all hook up. Your going to love it.
Old Jul 13, 2009 | 06:19 PM
basktb1188's Avatar
ok so do i use the a6 mani or the y8 mani anything major i have to do this it the 1st honda swap im more of a nissan/ DSM guy but im getting in the honda scene
BTW thanks for all the help so far
Old Jul 13, 2009 | 06:29 PM
Reckone's Avatar
Use the Y8 one as long as it's a manual trans intake. It's supposably the best oem D-series intake. You can run the A6 dizzy, and ecu- But you will not have vtec.
Old Jul 13, 2009 | 06:34 PM
basktb1188's Avatar
the y8 is a auto and the a6 is a auto...is that gonna be a problem?
my girlfriend isnt very friendly with clutchs lol
Old Jul 13, 2009 | 06:37 PM
BiG ChOr!Zo's Avatar
teach her how to ride (drive) stick
Old Jul 13, 2009 | 06:41 PM
basktb1188's Avatar
lol i tried meny times bro then all i can smell for a week is my clutch (rotten eggs) lol
Old Jul 13, 2009 | 06:45 PM
Reckone's Avatar
You should be fine to use the Y8 intake then, as long as you plan to leave it auto.
Old Jul 13, 2009 | 06:49 PM
Old Jul 13, 2009 | 07:11 PM
D16SiHatch's Avatar
even though her car is auto, and the intake is from an auto, it wont work. the iacv on the auto y8 im is different than the standard type iacv found on the manual y8 im. the obd0 ecu has no way of controlling it properly. so if you're going to keep the y8 then use the a6 dizzy (it will bolt up perfectly), and retain the a6 intake manifold.
Old Jul 13, 2009 | 07:43 PM
linkdeezie's Avatar
Its a straight swap without replacement. only 3 things need to be changed - the dizzy, the alternator, and the intake manifold. the dizzy from the a6 will bolt directly to the y8 head.
Old Jul 13, 2009 | 09:05 PM
JOEY-G's Avatar
you'll need to lengthen the wires for your cooling fan switch and use the connector from the y8. the switch is on the back of the block on the a6 and the y8 has it on the thermostat housing. the torque converter flexplate may be diffirent. id use the one from the a6 to be safe.
Old Jul 14, 2009 | 09:45 AM
basktb1188's Avatar
Thanks
Old Jul 29, 2009 | 02:17 PM
basktb1188's Avatar
old post but im in the middle of the y8 swap... will the acc.s work on that y8? like the alt. , PS, AC.?
Old Jul 29, 2009 | 04:57 PM
es.roadster's Avatar
you would need to swap over your alternator,ps and ac from your old motor to the y8.
Lasty K
27
Nov 1, 2017 09:03 AM
khmaiabz
Oct 4, 2008 02:12 PM
98civicHI
11
Jul 25, 2007 11:33 PM
EJ82door
Jan 28, 2007 01:59 PM
v8killa91
Jul 18, 2006 03:06 PM
