Ef won't start. Starter not engaging.
Old Jul 13, 2009 | 11:32 AM
jpnolan's Avatar
Default Ef won't start. Starter not engaging.
Ok so heres my problem. I turn the key and I can basically hear the rod of the starter shoot, engage and die? But I can't even get a single crank. Please someone help. Enough power in battery.
Old Jul 13, 2009 | 12:52 PM
mouab18c1's Avatar
Default Re: Ef won't start. Starter not engaging.
try a new starter
Old Jul 13, 2009 | 01:55 PM
jpnolan's Avatar
Originally Posted by mouab18c1
try a new starter
Thanks thats all I could guess at this point.
Old Jul 13, 2009 | 07:53 PM
jpnolan's Avatar
So we tried push starting it today. With no luck... Also it came to an IMMEDIATE stop
Old Jul 13, 2009 | 07:56 PM
srmofo's Avatar
put a wrench on the crank pulley and see if it turns over by hand, check your oil level....sounds like you locked it up
Old Jul 13, 2009 | 08:03 PM
jpnolan's Avatar
Can't check atm... But locked up? How do I fix this? Enough oil.
Old Jul 14, 2009 | 07:39 AM
jpnolan's Avatar
The crank pulley will turn over :D what now? Thanks for the help!!!!!!
Old Jul 14, 2009 | 07:59 AM
delsolproblems's Avatar
Try a jump start from a big vehicle with a big alternator while they rev their motor. When did this problem start and what was the car doing the days before? Is there any chance the cam timing is off?
Old Jul 14, 2009 | 08:07 AM
jpnolan's Avatar
I'm going to get my starter tested..... Its just been sitting but it was running about a week before. Cam timing wouldn't cause no crank.
Old Jul 14, 2009 | 08:40 AM
jpnolan's Avatar
Starter passed.
Old Jul 14, 2009 | 08:57 AM
mouab18c1's Avatar
try to jump start it then...check all fuses
Old Jul 14, 2009 | 10:20 AM
jpnolan's Avatar
All of this came down to a dead battery. SORRY GUYS. F-ing autozone said it was charged but **** was dead.
Old Jul 14, 2009 | 01:45 PM
mouab18c1's Avatar
funny..glad you figured it out
Old Jul 14, 2009 | 02:58 PM
srmofo's Avatar
you threw me off when you said "it came to an immediate stop", glad to hear it was an easy fix
GiboGSR
Nov 24, 2017 07:53 AM
seane51
Jan 17, 2014 03:50 PM
EFS463
Aug 14, 2013 05:10 PM
bbrian
Jan 23, 2005 09:36 AM
