does anyone know how to remove del sol center dash console?
I'm trying to replace original bulbs with bright red leds, I've succesfully installed it on the cluster, but having difficulty removing the center dash(climate control), if anyone can help me that would be great, thx in advance.
Remove the armrest console. Then remove the shifter console. Then remove the stereo.
You will need a small philips screwdriver. There is a screw on the bottom of the back A/C controls that is vertical. Remove that screw. Then get underneath the passenger side of the dash and remove the heater valve cable from the plastic peg and unclip it from its clip. You can now remove the climate controls.
evilcivilian
Feb 12, 2008 04:09 PM
