93 Honda Civic wont start.
Old Jul 13, 2009 | 05:25 AM
coasttime's Avatar
Icon6 93 Honda Civic wont start.
Hello,
I will give you a clear look at what is going on. I was driving my car to the store and I got about a 1/8 mile from my house and my car shut off but all the dash lights came on. So I pull over to the side and try to start my car again and no luck. I noticed that there was a burning smell so I got the car back to my house and read on some forms that the main relay can go bad. I pulled the main relay and it did smell burnt on the relay it says (RZ-0132) so I went to a junk yard and pulled a relay of a integra (RZ-0159) they both do the same thing when I plug them in. I turned the car to the start position and the relay clicks once and I do not hear the pump prime. So i checked to see if there is spark and there is no spark but the distributor was check as good. I am in between a rock and a hard spot. What could be the problem does the relay have to be the RZ-0132 and is it supposed to have two clicks or just one? Where is the 120v fuse located? Please just throw me some ideas thank you.
Old Jul 13, 2009 | 01:04 PM
Targa250R's Avatar
be professional
Default Re: 93 Honda Civic wont start.
Ignition coil or ignitor.
Old Jul 13, 2009 | 01:17 PM
Former User's Avatar
No spark or fuel -- You can check for blown fuses, but I think the ECU may be fried.
Old Jul 13, 2009 | 04:25 PM
coasttime's Avatar
I checked the ignition and the coil. I read on some threads that there is a 120v fuse do you know where that is at? And my relay smells burnt!
Old Jul 13, 2009 | 04:48 PM
Pull out the ECU and inspect it.
Old Jul 13, 2009 | 05:05 PM
slow96lude's Avatar
I have heard of instinces of having to put in the same main relay. Try resoldering the old one. Or buying a new one oem. It is possible that you got a bad one from the junk yard I have done it before too. Do like ron said to. Take out the ecu and look at resistor at c14 and see if its fried
Old Jul 13, 2009 | 06:38 PM
40mpg_dx00's Avatar
Do you have aftermarket electrical stuff that somebody else may have installed? That crap could fail and cause other problems.
I'm not ruling out the ecu, in fact I agree that it is the likely cause, but don't overlook other people's potential screwups because the problem may just come back
Old Jul 13, 2009 | 08:34 PM
Awinner's Avatar
New User
I'd check the ECU, and even the distributor...I've had a very similar problem. Replaced the distributor; all is good.
Old Jul 22, 2009 | 03:16 AM
coasttime's Avatar
So I pulled my ECU and it smells burnt just like my relay. I got a new Relay in and it did not start it did the same thing. Just cranked and no spark or fuel. So now I got to get a new ECU. But I do not know what caused my car to do this. Is it a bad ground or what? I cant find any burnt wires.
Old Jul 22, 2009 | 04:37 AM
coasttime's Avatar
Ok so I just opened my ECU and it looks like a fire was set inside of the box. So my question is what causes a ECU to burn up? Can a bad ground cause it?
peteyparado
Feb 9, 2014 07:38 PM
06turbocivic18
Oct 13, 2009 10:04 AM
C-RICKS
Aug 15, 2009 06:05 PM
ge_itr
Jun 1, 2007 09:00 AM
silentblackhat
Jun 10, 2005 07:55 PM
