Which spare tire to use after EG-Integra front brake conversion?
Old Jul 11, 2009 | 11:27 PM
fungus mungus's Avatar
Default Which spare tire to use after EG-Integra front brake conversion?
I did a full Integra brake conversion (rear discs, larger fronts) on my EG hatch last week and it occurred to me today that my donut spare will only be good for the back wheels if it's ever needed. So my question is will a 14" Integra donut spare work for the fronts? I don't recall if 94-01 Integras came with 14" wheels or not. If so, will it fit in my trunk where the existing donut sits?
fm
Old Jul 12, 2009 | 01:03 AM
Ruben19's Avatar
Default Re: Which spare tire to use after EG-Integra front brake conversion?
should fit. anything above 14 should be kool
Old Jul 12, 2009 | 05:53 PM
pepsiDX20's Avatar
Go to junkyard and pick up 14 inch steelie....
Old Jul 12, 2009 | 06:23 PM
Jackal6042's Avatar
X2, if you need to replace the spare you might as well get a full sized.
Old Jul 12, 2009 | 07:57 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
A 90-01 integra donut will work. A civic 92-95 EX with ABS donut will work. A 96+ EX or Si will work.
Old Jul 12, 2009 | 08:19 PM
NOFX's Avatar
H-T White Ops
He wants the spare to fit in the hole in the trunk still. So a full sized steelie won't fit.
Old Jul 12, 2009 | 09:10 PM
B serious's Avatar
I have a 15X7 full size with a 195/55/15. It fits in the hole fine. The trunk mat is a little bowed up...but it still fits fine. I have to go to the hardware store and find a ??M10?? bolt with a wing nut that's long enough. Or maybe I'll buy one from Honda from the new odyssey or whatever else.
I think a 14'' steelie of stock width should fit pretty well without bowing up the trunk mat too much.
Old Jul 12, 2009 | 09:14 PM
NOFX's Avatar
H-T White Ops
I recall trying to fit a steelie into either a 6G Civic coupe or hatch and it didn't fit with the standard tire size. It sat up too high and wouldn't lock in place with the tie down. Not to mention the cover (floor) wasn't going to ever fit over it.
Old Jul 13, 2009 | 01:02 AM
Jackal6042's Avatar
Some threaded rod with some locking nuts, problem solved, just cut to fit, round it off with a grinder so your wing nut goes on smooth.
Maybe I'm crazy, but I dont really care if the rotted old trunk floor bulges a little or if I have to cargo strap a spare tire into the trunk. Is this Honda-Tech or Honda-GroceryGetter?
Old Jul 13, 2009 | 01:19 AM
NOFX's Avatar
H-T White Ops
It's Honda-Tech, not Beat-The-****-Out-Of-What-Might-Still-Be-A-Decent-Honda.
For example, my cars are both in nice shape. My trunk floors are not rotted, nor are any other parts on my cars. The floors also don't bulge.
Plenty of ways have been mentioned for him to get a spare that fits without just going for the route that has no benefit other than it might be easier to find a full size steelie over a certain spare. It's not like a '96-'00 EX spare will be hard to find though.
Your post does not help with the OP's requirements in his first post. He wants a spare that will fit on his upgraded brakes but will also fit in the space for the spare in the trunk.
Old Jul 22, 2009 | 09:43 AM
Thanks everyone for your answers. I'll look for a 96-00 EX spare at the junk yard...lots of these around here. Although my spare cover is on it's last legs, I intend on rectifying that.
fm
ColombianEk9Boy
Jul 10, 2015 02:40 PM
JdmCoupe91
Suspension & Brakes
Mar 6, 2012 09:27 AM
esoterEK..
Nov 17, 2005 07:07 PM
fathergoose
Aug 23, 2004 05:58 PM
Paste
Aug 21, 2002 05:03 AM
