Will integra LS rear disc brakes fit EK's????
might be a dumb question but..
let me know..
i got a good deal on some..j/w. if it'll work..
thanks.
let me know..
thanks.
Re: Will integra LS rear disc brakes fit EK's???? (esoterEK..)
yea, but not sure about the cables, i think you gota use si cables, and i think you need to use the integra brake booster and mastercylinder
anyone else? i too am planning to do this conversion
Re: Will integra LS rear disc brakes fit EK's???? (astroxtc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by astroxtc »</TD></TR><TR><TD CLASS="quote">yea, but not sure about the cables, i think you gota use si cables, and i think you need to use the integra brake booster and mastercylinder
anyone else? i too am planning to do this conversion</TD></TR></TABLE>
yea...the reason why im asking is because im not sure if LS is the same as GSR's..
im sure GSR's will fit though...
i also heard some people using civic boosters/mastercylinder and theyre doing fine..
anymore inputs help us out..
They will fit. I put the rear disc's from an LS on a civic (although it was a 92 civic, it doesn't matter).
Also you can use the e-brake cables, they only thing is they might be a little short. You could fix that by loosening the adjuster nut on the back of the e-brake handle.
Re: Will integra LS rear disc brakes fit EK's???? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">They will fit. I put the rear disc's from an LS on a civic (although it was a 92 civic, it doesn't matter).
Also you can use the e-brake cables, they only thing is they might be a little short. You could fix that by loosening the adjuster nut on the back of the e-brake handle. </TD></TR></TABLE>
alright..thanks!
alright..thanks!
I've got teg brakes on my 99 hatch. They will swap right on, the part about ebrake cables being short is kind of right. Its not the inner cable that is short the housing is like 1/2 inch shorter. You can use the cables though, I just left one of the hangers off and ziptied the cables up. Really you wouldn't even need to do that though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. »</TD></TR><TR><TD CLASS="quote">
anymore inputs help us out.. </TD></TR></TABLE>
DUDE search
teg booster=teg MC
LS, RS, GSR brakes all the same!
DUDE search
teg booster=teg MC
Cap'N Chronic
02-08-2012 11:11 AM
90DALS
11
11-06-2004 05:35 AM
AlienKrOZ
11-04-2003 07:23 PM
