mounting depth of front speakers on a 95 civic
Old Jul 11, 2009 | 05:57 PM
euroborn1's Avatar
Default mounting depth of front speakers on a 95 civic
i got a 95 4 door civic planning on hooking up a set of components...before i buy any anybody know what the mounting depth is for the front doors?
Old Jul 11, 2009 | 06:15 PM
98civdx's Avatar
Master Detailer
Default Re: mounting depth of front speakers on a 95 civic
i have no idea on the depth but you will need to cut out the bucket inside the door pannel...
after that most 6.5 speakers wil fit.
Old Jul 12, 2009 | 07:59 AM
JSPECSIR's Avatar
you can also swap the oem mount out for an aftermarket one or make an mdf one. many component sets will also come with these rings(alpine type r's have a great set, but these do need an amp to reach there full potential). just keep in mind proper mounting and some good sound deadener like dynamat extreme will play a critical role in how well you component woofers sound.
Old Jul 12, 2009 | 09:48 AM
fcm's Avatar
fcm
Old Fart
The stock speaker is a standard 6.5", [5" diameter mounting hole and a 2" mounting depth] an extra 1/2"-3/4" of depth can be gained by cutting a hole in the back of the speaker housing for the magnet of an aftermarket to fit through, you can also gain another1/2"-1" by using a spacer between speaker housing and speaker.
As mentioned replacing the stock speaker housing with a custom MDF housing will not only allow for up to 3" deep over-sized 6.5" even some 7" speakers it also will improve SQ by a lot. 94
Old Jul 12, 2009 | 07:23 PM
euroborn1's Avatar
is it true tht the 95 4 door lx models didn't come with rear speakers? mine has no speakers, and it does not look like there was ever any there..
Old Jul 30, 2009 | 07:35 PM
aquito's Avatar
i have a 95 LX sedan and i have 6.5 in the back...
Old Jul 30, 2009 | 08:00 PM
Civic Si Kid's Avatar
it really depends on your car when new
But I am 90% sure that it at least comes with wiring.
mrgoodbar
Audio / Security / Video
13
Aug 13, 2008 12:31 PM
farrago
Jun 10, 2008 08:31 AM
Kryptonite
Jan 13, 2004 04:31 PM
ALF
Apr 15, 2003 03:52 PM
dazco
22
Jan 1, 2003 02:49 PM
