resistor box install
i know this has been talked about and i have used the search button....but does anyone have any pictures of a resistor box install in a ef sedan..i have a 89dx
Are you doing a MPFI swap? I used this guide, it has a section on the resistor box install.
http://www.fourthgenhatch.net/mpfi.html
thanks..i have 450 dsm injectors....i know all about the yellow and black wires from the injectors but the red wire is the problem where do u i connect the red wire ...need a an illustration
so connect it to the red wire were the injector wires are ....ok...now do i cut the injector wires or do i (yellow and black ) splice them all together with the black wires from the box?
Happyman
Aug 26, 2003 09:08 PM
