O2 cell but only around 60mph!
Old Jul 10, 2009 | 01:01 PM
Spence's Avatar
Default O2 cell but only around 60mph!
Ok so i just picked up a stock 90 honda civic and it has a brand new o2 sensor in it. When cruising around 60mph it with code a o2 sensor. I know the sensor is good so what gives here?
Help a brotha out
Old Jul 10, 2009 | 03:02 PM
texasnick's Avatar
Default Re: O2 cell but only around 60mph!
Does it do it all the time, or just every once in a while?
Have you checked the wiring to the sensor to make sure it's all good?
Old Jul 10, 2009 | 03:27 PM
Spence's Avatar
The wiring to the sensor seems great looks brand new! As far as doing it all the time i have only had the car a little over a week so im not sure
Old Jul 11, 2009 | 11:10 AM
Spence's Avatar
no one else has a opinion?
Old Jul 11, 2009 | 12:07 PM
johnnyonth3spot's Avatar
I throw a o2 code when I got my megan header after letting the engine warm up and if I let off the gas for more than 10 seconds without downshifting I would get a code. It stopped after I moved my o2 sensor to my downpipe next to my cat
Old Jul 12, 2009 | 09:16 AM
Spence's Avatar
Dude the car is all stock
Old Jul 13, 2009 | 06:04 AM
Hondaisok's Avatar
Help a brotha out
My 91 hatch does the same thing once in a blue moon when I'm on the interstate. Once I reset the code by pulling the hazard fuse, it usually doesn't come back again for a long time.
Old Jul 13, 2009 | 06:23 AM
rustbucketrex's Avatar
Mine threw an O2 code when my timing was off. Check your cam timing, then set your ignition timing. The O2 sensor is reading that the emissions are off.
Old Jul 13, 2009 | 07:53 AM
raene's Avatar
You could also wire in a 4-wire O2 sensor. One-wire O2s are utter crap.
If it's one of the cheap knockoff replacement O2s you may have simply gotten a lower-quality version. I've definitely heard of "new" O2s throwing O2 codes for being lazy.
As stated, it's not a code because the O2's bad, it's a code because something else in the tune is off - it's running rich for some reason.
Old Jul 13, 2009 | 09:42 AM
Spence's Avatar
Thanks thats the best answer i have gotten
Civic98KH
15
Dec 10, 2012 08:26 PM
Bossup!
Sep 9, 2009 07:35 PM
j3nniii
Oct 15, 2008 12:59 PM
GSRacer
Oct 8, 2001 06:59 AM
