Honda S2000 Honda S2000
Just curious...who else has this happened to? (Wheel Bearing Issues)
Old Jul 10, 2009 | 12:09 PM
PeakBoostSi's Avatar
Default Just curious...who else has this happened to? (Wheel Bearing Issues)
It seem to be a common prob for the S2k
My rear left bearing went out...and needs replacing. 01 S2k with 80k miles...just regular spirited driving here and there...
Who else has had this happen? How to prevent it?
Old Jul 10, 2009 | 02:56 PM
EH6TunerDaniel's Avatar
Default Re: Just curious...who else has this happened to?
I just replaced my left rear today. It was the second one in a week too. I am not sure what caused the first two to go bad.
Old Jul 10, 2009 | 08:08 PM
95 integra's Avatar
Second wheel bearing in a week....failure on your part. No problems here.
Old Jul 11, 2009 | 08:46 PM
Um, seriously, how is it I failed to install the bearing properly? It only goes one way, its not like its complicated to install.
Old Jul 11, 2009 | 09:00 PM
95 integra's Avatar
Well, if you dont install the axle nut, it will turn to **** real fast. Even if you did install it correctly, if it failed again within a week (vs. the 150k+ they usually last) then there is some other issue causing your problem that you failed to identify.
Old Jul 12, 2009 | 10:23 AM
White Smoke's Avatar
i my honda
Global Mod
Something is seriously wrong if you destroyed a bearing in one week. I would naturally assume install error as well.
Old Jul 13, 2009 | 11:47 AM
5.56's Avatar
What kind of sound does it make when the bearing fails? Is it sort of like a thumping sound when you start moving?
Old Jul 14, 2009 | 04:57 AM
rice4life's Avatar
a lot of racers have problems with rear wheel bearing because of the heat from the rear brakes. rear brakes are usually hotter than the front because it's a solid disk.
Old Jul 14, 2009 | 07:10 AM
Black S2K's Avatar
108k here and no problems yet but i have herd of it being a comon problem so im waiting for mines to go
Old Jul 14, 2009 | 02:19 PM
starchland's Avatar
more than likely it is related to the axle nut torque
Old Jul 15, 2009 | 05:12 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
dont they have a TSB on that???
Old Jul 15, 2009 | 10:53 AM
S2kGuy07's Avatar
i went through 4 actually...all right side though
when you have a very low car like i did its going to happen no matter what
Old Jul 17, 2009 | 06:23 AM
boostedh22a's Avatar
Default Re: Just curious...who else has this happened to? (Wheel Bearing Issues)
So you guys that have gone through multiple wheel bearings, do you just replace them routinely, or have you fixed the issues that have caused them to fail?? I'm getting some noise from mine here recently.
Old Jul 17, 2009 | 02:09 PM
This is exactly what I want to get at...
How to prevent it?
I really dont want to have to repair them often. It took mine 82k miles to go bad...just dont want to replace my right one soon...
BUMP!
Old Jul 17, 2009 | 02:11 PM
Sorry for the NOOB question but what is TSB?
Does it refer to some recall...?? Should the dealership have replaced this at no cost? LOL
Old Jul 18, 2009 | 08:17 AM
Well from what i have been able to find out you cant do shiz about it!!!! just retorque the axle nut periodically and hope it lasts!!
Old Jul 18, 2009 | 10:39 AM
Brice.Hayden's Avatar
Service Bulletin
Old Jul 23, 2009 | 09:30 AM
thanks
cmasino
Honda Civic (2001 - 2005)
Jul 25, 2017 01:13 PM
Junior1023
Nov 19, 2013 09:56 AM
Steve90HB
Feb 19, 2005 04:58 AM
yung98gsr
Feb 18, 2005 09:28 AM
TurbodCX
Apr 30, 2003 08:40 AM
