ej1 no power..
Old Jul 10, 2009 | 10:09 AM
nolakid504's Avatar
Default ej1 no power..
so for the most of you who have been reading and helping on the ej1 well i got the new harness in and hooked up. put the battery in and go to start it up.. turn the key to on nothing.. nodda..
so i go fiddle with all the grounds and power wires under the hood and still nothing.. so i just kept turning the key off and on and it finally came on and powered everything but still didnt start up and run.. after 6 seconds of turning it over i turned the key to off and back to on and again nothing.. now it wont come back no matter what..
pics of everything under the hood in just a second..
so question.. if my ignition was bad this whole time, would it have kept the power i needed from my injectors and stuff?
there is no clicks, dash lights do not come on, and horn still works.
for those of you who dont know about the car..
1994 ex coupe
d15b2 with dx long gear hydro trans.
new plugs,dizzy,wires,gaskets,seals,harness,battery,ec u,main relay,fuel pump, fuel filter, injectors.
Old Jul 10, 2009 | 12:28 PM
ek-g6's Avatar
Default Re: ej1 no power..
If its clicking when your turning the key, then main relay could be bad. Maybe could be ignition switch.
Old Jul 10, 2009 | 12:29 PM
nolakid504's Avatar
there is no power to anything at all. all the fuses are good not one is blown.
the only thing working on the car is the horn and brake lights which don't require the car to be turned 'on'
Old Jul 10, 2009 | 12:38 PM
ek-g6's Avatar
Could the whole fuse box be bad? or maybe not even hookedup?
Old Jul 10, 2009 | 12:40 PM
nolakid504's Avatar
HIGHLY doubt that being as it was working 2 days ago just fine..
after i swapped the intake manifold,t-stat housing,water pipe, harness
cleaned all the grounds with a wire brush.
triple checked all the connections.. unplugged and re plugged the harness
still got nothing..
Old Jul 10, 2009 | 12:46 PM
ek-g6's Avatar
Ignition switch i think went bad, since you were turning the key back and forth, and then it gave out after so many tries.
Old Jul 10, 2009 | 01:42 PM
nolakid504's Avatar
well i just got back from autozone got a new switch.. well when i get it in it doesnt lock into place and the key will not turn no matter what. so can i assume the the assembly is bad?
Old Jul 10, 2009 | 01:46 PM
gsrpedro's Avatar
check all the fuses and relays....
Old Jul 10, 2009 | 01:49 PM
nolakid504's Avatar
there is no power to anything at all. all the fuses are good not one is blown. same for the relays.. everything on this car is new or used but known working, mostly new..
ive been at this car for over a month its got a damn curse on it.. one thing gets fixed another thing goes wrong..
Old Jul 10, 2009 | 01:51 PM
gsrpedro's Avatar
do the battery has charge???
Old Jul 10, 2009 | 01:52 PM
nolakid504's Avatar
of course..
but the problem is being that the new ignition lock cylinder isnt locking into place would it mean i have to replace the whole assembly?
Old Jul 10, 2009 | 01:53 PM
gsrpedro's Avatar
how do u know if u say that u dont got power at all???
Old Jul 10, 2009 | 01:56 PM
nolakid504's Avatar
i live 100 ft from a auto store.. they checked it this morning..
read the post above..
people please dont treat me as an idiot. ive pretty much tested all that i can test..
obviously if the horn works and the brake lights work with no problem obviously the dash lights would atleast come on.
im focused on the ignition problem now.
Old Jul 10, 2009 | 03:07 PM
ek-g6's Avatar
Are you just replacing the ignition key and tumbler assembly? If so your not going to fix the problem. you need the entire ignition switch assembly.
Old Jul 10, 2009 | 03:11 PM
nolakid504's Avatar
so not what i wanted to hear.. $230 from auto store
guess im hitting up junk yards tomorrow...
anyone got a write up for a easy pull out?
Old Jul 10, 2009 | 04:37 PM
nolakid504's Avatar
so i tired putting in the original lock cyl and wala it went in and locked in. turn the key and dash lights come on..
friend of mine stopped by so i had him check for spark and upon inspecting it shut off again so im like well its keeping it from locking up so something is wrong here..pull plug wires and..
all i can say is wow. this is kind of my fault.. junk yard wires that looked brand new..
pic is after i pulled the tube off of course.. and no the other end was obviously never there so its wasn't getting spark to those cylinders..
cyl #1 & 2 wires.
Old Jul 10, 2009 | 04:41 PM
shogee's Avatar
wow no offense but thats a mess under the hood
Old Jul 10, 2009 | 04:45 PM
nolakid504's Avatar
wiring or the junk on the firewall & strut towers?
only thing bad on the wiring is that one tie down for the harness on the drivers strut tower is bolted in.. besides that its stock wiring..
the junk is from the previous owner... its getting sprayed off just more worried about getting it running and driving than cleaning it..
a wire tuck will be done once i have my funds back..
Old Jul 11, 2009 | 04:01 PM
nolakid504's Avatar
no power problem has been fixed. guess my grounds didnt like a painted/dirty fender wall lol.
and on to the next problem..
so when the motor is started up and running.. if i try to give it any amount of gas it dies..no its still not starting on its own.. use of starter fluid and it starts right up.
btw its a d15b2 with a b7 im,t-stat,water pipe.
what would cause this?
also my injectors are spitting like water pistols and not in a spray form. is that normal or are they stuck/clogged?
also, the spark im getting from my dizzy is orange and not yellow like it used to.. defected or normal?
darkmentality
May 15, 2013 03:09 PM
4drctr420
Honda Civic (2001 - 2005)
Dec 6, 2011 02:10 PM
upallnite
Dec 27, 2008 06:59 PM
Jrodk636
Oct 27, 2006 09:28 AM
