Tiny cracks in flywheel OK?
Old Jul 10, 2009 | 08:12 AM
crex23's Avatar
Default Tiny cracks in flywheel OK?
I'm gonna use my old flywheel with a motor swap I'm doing, but when I took it off there were tiny hairline cracks on the surface. I could barely feel them there. If I get it resurfaced, will it take care of the cracks? Is this normal? The flywheel/clutch assembly also had red dust all over it. Just need to know if it is okay to use.
Old Jul 10, 2009 | 08:17 AM
Link16's Avatar
Default Re: Tiny cracks in flywheel OK?
I personally would put in a new flywheel, they are reasonably inexpensive, so why risk having to pull the trans again?
Just my .02
Old Jul 10, 2009 | 08:18 AM
jhammond_82's Avatar
Reject Papi
i would take it to a welding shop, and have it magnafluxed. its where they use a powerfull magnet, and iron oxide dusting. the magnet, magnetizes the entire object, and the iron oxide dust covers everything that is cracked. if there are internal cracks you will find out quick. not sure if getting it resurfaced would work or not the only thing i can tell you, is to try it and see what it looks like afterwards.
Old Jul 10, 2009 | 08:57 AM
fireant's Avatar
If the cracks are on the clutch mating surface, they can cause wear and performance issues just like cracked brake rotors do. Worst-case scenario is if it breaks apart, it could become heavy shrapnel that could go through the bell housing, your hood, your firewall.
I would get a new one or a good used one for peace of mind.
Old Jul 10, 2009 | 10:46 AM
johnnyonth3spot's Avatar
If you wire me the shipping and handling ill give you mine off of a 91 si hatchback just needs resurfacing. Ill post a pic later when I dig it up.
Old Jul 10, 2009 | 11:39 AM
Dark_Teg's Avatar
I would never even consider reusing a cracked/damaged flywheel. I dont even use stock flywheels in race applications if they are like new.
I have seen flywheels/clutches come apart and shoot through the floorboard and basicly total the vehicle. Not to mention shrapnel lodged in your leg would suck!
Old Jul 10, 2009 | 12:48 PM
SIred91's Avatar
Rainman
Old Jul 10, 2009 | 01:39 PM
spoonfedcrx's Avatar
Are they actual cracks or just look like cracks on the face? Sounds like it needs a resurface. You got pics?
Old Jul 10, 2009 | 05:57 PM
crex23's Avatar
They look like very tiny hairline cracks. Some of them I barely can feel. I ended up buying a new flywheel from Autozone for $60 today, I didn't realize they were this cheap. Thanks for the help.
ganjasnack
Aug 12, 2008 12:02 PM
LSEGHATCH
15
Jun 27, 2006 04:42 PM
See Are X
Jun 22, 2003 02:08 PM
EGHatchy
May 30, 2002 05:18 PM
Dirty GS-R
Feb 5, 2002 05:08 AM
