To Resurface Or Not To Resurface Flywheel
Old 06-27-2006, 11:13 AM
LSEGHATCH's Avatar
Default To Resurface Or Not To Resurface Flywheel
Well in my quest to swap out the clutch, I've hit BIG bump. I can't get the flywheel off.....with anything. There aren't any burns in the flywheel so I'm wondering if I should take a chance and not resurface. I've soaked the bolts in PB which might not have been the smartest thing if I'm going to leave the flywheel on.
What would be the best way to insure all of that PB is gone if I don't resurface?
Old 06-27-2006, 11:25 AM
LSEGHATCH's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (LSEGHATCH)
Well i cannot for the life of me get but one bolt out of the flywheel. Thus, I'm not resurfacing. Can I just sand it down if a very find grit and the spray clean with brake cleaner?
Old 06-27-2006, 11:39 AM
huntarrr's Avatar
When I replaced my clutch, I kept the same flywheel and didn't resurface it. I haven't had a problem with it for 6000 miles..
Most anyone would tell you to surface the flywheel if you have it out. "It's always a good idea" and yes, it is. But it's not entirely a necessity.
Old 06-27-2006, 11:46 AM
LSEGHATCH's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (vsm98civic)
Well I just hit it with 100 grit sand paper and will go another round just to make sure there are no unseen ridges. Also doing it in a swirling pattern as do the milling machines
Old 06-27-2006, 11:48 AM
spikiexmikie's Avatar
have you tried using like a breaker bar and a long cheater pipe to get the last bolt off? well just thing of the flywheel like ur brake rotors, its wise to resurface it if your replacing the clutch. it will work better and last longer.
Old 06-27-2006, 12:00 PM
LSEGHATCH's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (spikiexmikie)
Trust me I've used the following methods:
Breaker bar 3.5'
Impact 80psi
Heat + Impact
Lube + Impact
Nothing and I don't want to fucke up the bolt head for the next guy who works on it. Like I said, I've been sanding in circular motions getting is as preped as possible, when others have just thrown on a new clutch and have had no problems.
I'm not one for half assing things whenever possible.
Old 06-27-2006, 12:01 PM
94hatchling's Avatar
personally, if you are just one bolt away, dont cut corners, and just take the flywheel off and have it resurfaced.
it is cheap insurance once you have gone this far and have everything else already off. also, torque all the bolts to the proper specs too when reinstalling the flywheel and bolts you removed. if they come loose, it can cause some major damage, and if not, you will still have to tear everything down again to get to it.
just do it the right time the first time.
Old 06-27-2006, 12:26 PM
cambopheonix56's Avatar
Default Re: (94hatchling)
Might as well. GL with that last bolt.
Old 06-27-2006, 12:32 PM
LSEGHATCH's Avatar
No no no, I've only been able to get one bolt off.
Old 06-27-2006, 12:43 PM
RedEj8's Avatar
That doesnt sound right....U should be able to get all the bolts off...An impact will most likely not work.I had a to use a big cheater pipe. But it still wasnt that hard. Do to have something to keep the motor from spinning over while ur trying to turn them? I supposed u will be alrite not resurfacing as long as u get all the glazed material off. And find a small straight edge to make sure the surface is level.
Old 06-27-2006, 12:51 PM
hatchi's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (reddohcvtec)
are you having problems taking it off because the flywheel turns when you try to take off the bolts??
Old 06-27-2006, 01:19 PM
LSEGHATCH's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">are you having problems taking it off because the flywheel turns when you try to take off the bolts??</TD></TR></TABLE>
no
Old 06-27-2006, 01:52 PM
Banned
CardDealer's Avatar
Modified by CardDealer at 9:43 AM 11/16/2006
Old 06-27-2006, 02:10 PM
LSEGHATCH's Avatar
Default Re: To Resurface Or Not To Resurface Flywheel (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">All i did was sand it with 100 grit in swirling motion and spray it down with brake cleaner. My flywheel had 80,000 miles on it at the time. I'm at 100,000 now and everything is ok....OEM clutch. As long as there isnt any major wear or burns I'd think you'll be fine. </TD></TR></TABLE>
Just what I wanted to hear, I've been sanding for the last 1.5 hours with 100 grit. Hopefully I have the same outcome as you.
Old 06-27-2006, 03:07 PM
Slamaccord's Avatar
I wouldn't run a chance with maybe snapping the bolt. Then thats a big project ahead of you. Do as you said sand it down and use some brake cleaner to make sure you have a good contact surface. Make sure its clear of dirt and debris.
Old 06-27-2006, 04:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">No no no, I've only been able to get one bolt off.</TD></TR></TABLE>
Oh well fvck that. Sand it.
1Bluegsr
11-25-2011 05:05 PM
immalooser
10-18-2005 08:08 PM
b16a27
11-05-2004 04:43 PM
MintFlavored
04-27-2004 06:08 PM
NightHawkC5
03-18-2003 11:31 AM
Quick Reply: To Resurface Or Not To Resurface Flywheel
