Got the head off to replace HG, anything i should check/do while its off?
Old Jul 9, 2009 | 06:39 PM
aleks77's Avatar
Default Got the head off to replace HG, anything i should check/do while its off?
hey guys i got the head off to replace the headgasket, which wasnt blown or cracked it simply had like a clean area around #4 cyl and you can see where combustion met coolant. The head also had a tiny tiny indent in that area, so its getting milled right now, valve seals are getting replaced, pressure tested and cleaned.
Just wondering if i should check anything while the head is off, anything i should look for at the cylinder walls or the pistons? I got a **** load of sludge on #4 cyl, and a little bit on all others, ill post pics later!
Thanks for any suggestions
Rickdogg
24
Dec 15, 2011 02:11 AM
g0tgot
Jul 3, 2009 07:14 PM
charlie_sohc
Dec 14, 2007 12:37 PM
DreamCatcher
Nov 27, 2005 02:28 PM
dbman96
May 13, 2002 03:21 PM
