Headgasket blew chip on head
The headgasket blew the other night on my ladies car so I took it apart and I find this chunk missing off the head by the water jacket can I reuse the head if I get it resufaced. The headgasket blew on the opposite side of the chip
Re: Headgasket blew chip on head
i have never seen damage that far away from the combustion chamber from a blown head gasket
i would advise you get the block checked for warpage, it may need to get resurfaced or replaced if its out of spec
but honestly since the area clamping on the blast ring area isnt touch, resurfacing the head seems like it would work
They're open because the camshaft is still attached to the head and pressing down on the valves.
Hey, I hate to sound like a salesman, but I've got a used cylinder head for a D16Y7 for sale in the Marketplace here.
Probably needs to be checked for warpage, but it should be good.
*shot by everyone*
Good luck!
*shot by everyone*
Good luck!
Nice! So is this what happens when you do not change your radiator fluid and allow it to corrode your cylinder head?
You could try grinding out the corroded metal and plugging the hole in the Aluminum with Steel Epoxy, and then using a stone to flatten the surface. Think of yourself as a dentist. This may not be a good idea, but it may work. I've never tried it. See what your machinist says about the idea and definitely have the head resurfaced
Hmm, by looking at the pic I'd say no. But the only way to be sure is to take a micrometer and gauge the depth of the corrosion.
The machine shop will take off at least .001" depending on how warped the cylinder head is. The corrosion looks pretty deep.
On the intake side of the head you will see a tab on each corner. Inside the tab is a little square. That's your limit on how much you can machine off. If the machine shop hits the square the head is ruined.
I wouldnt fill that with a steel epoxy considering that the epoxy and aluminum have different temp limits, just ask your machine shop before you do anything
wow you guys are retarded. epoxy on the head wtf is this.
just get that thing filled with aluminum weld and have the head resurfaced
that head looks like is has 950k miles on it
^^^ this, hell, i have a Y7 head sitting in my garage that i'll never use, just need to have it stripped down/cleaned/put back together and it would be cheaper than restoring that head...even comes with an intake manifold
OP, i wouldn't even worry about it. the gasket doesn't seal there.. check and see of the head is still flat, just leave that ****, slap a gasket on it and roll. pretty sure that a little divot in a cooling jacket hasn't compromised this high-revving high-horsepower engine's operating potential. but if the machine shop is going to charge more than $70 bucks to check it and resurface your head, just go to a junkyard and get another one.
K im gona just take it to a machine shop see what they say and have it tested and resufaced im sure it should be fine since the gasket blew on the opposite side of the chip but I a problem with the car bubbling out the overflow tank u guys think head might be cracked? Also I had no water in the oil till the headgasket blew
i gotta z6 head for a mini- me swap ready for sale lol better upgrade and to get rid of that ugly beat head you have. but if u shave enough to remove the chip your going to need an adjustable cam gear to get timing correct.
Seagull Management
What engine? If it's a D-series, especially a D15B7/D15B8 don't waste your time with it. They tend to just keep blowing headgaskets every 6 months to a year after.
So even if I buy a new head it s gona blow the gasket why would it do that cause I dont have money for a new motor
