aem fuel regulator
Old Jul 9, 2009 | 06:19 PM
nihad's Avatar
Default aem fuel regulator
Ok i have a aem fuel regulator its not universal its the one that bolts to the rail older honda style. What fitting should i have inside it so it is compatable with a walbro 255..
And is it normal to drop in vacuum from 22 to 13 from stock d16 injectors 235cc to 780cc
they are peak and hold style.. I was thinking its doing this because its untuned yet this was at idle.... about 40-42psi on the regulator at idle..
Old Jul 9, 2009 | 06:26 PM
kyden's Avatar
Default Re: aem fuel regulator
get it tuned before you ruin the motor.
Old Jul 9, 2009 | 06:29 PM
Turbo-LS's Avatar
x2
Its probably pig rich therefore barely running hence the loss in vacuum
Old Jul 11, 2009 | 08:03 AM
nihad's Avatar
no i am not driving it anywhere..
Old Jul 11, 2009 | 08:17 AM
96 GSR-T's Avatar
get a basemap for your injector size and setup before you mess something up.
just use the middle sized orfice and bring the others with you to the tune just in case.
dunkd
Feb 10, 2008 06:22 AM
superturboprelude
May 27, 2007 08:34 AM
S88HON
Oct 22, 2004 12:09 AM
thehondaguru
Apr 20, 2004 08:51 AM
