fuel pump the same? eg's and ek's?
Not necessary. i have a 92' civic hatch sohc and a 00 civic si dohc. i swapped both fuel pump just to experiment if both fuel pump are compatible with each other. And found out that they were, with no issues at all.
Where did you get this info? I'm confused how it would do that even with a higher LPH rating because the fuel pressure regulator would just end up sending more fuel down the return line...
well yeah when you swap in a bseries your supposed to use the bseries fuel pump.
i have a gsr and using a sohc pump and in first it sometimes bogs really hard, through turns too when i take sharp turns and get back on the throttle it seems like the pump isnt sending enough fuel
bad info, sorry
92-00 civics OEM fuel pumps support any swap, whetehr it be another D series, B series, H, F, or K, even J swaps can use the stock pump
just doublecheck to make sure the pump is healthy
thats the TANK causing it to lose gas, not the pump
simple solution is to simply have half a tank or more at all times. hopefully you are not driving like that on the streets, because that is a very stupid thing to do
any fuel pump will bog on hard turns if you are using the stock fuel tank. there isnt a good enough baffle for sporty driving.
i dont see why it stupid?
It is stupid to get lower than 3/8 to 1/4... The reason being your Stock fuel pump is cooled by the gas. It relies on it to keep cool and when you get low in your tank then you un-submerge the pump which causes it to heat up. The more times your fuel pump goes through this cycle the more likely it is to fail. Also any build up in your tank is now being suspended lower in it so your pump is more likely to suck it into the sock. Fuel pumps are pretty fragile pieces of equipment and it does not take a whole lo to make something go wrong with them.
EG2 SiR
Aug 19, 2003 10:14 AM
