Serious Help From All ITR peeps
Old Jul 9, 2009 | 02:18 PM
enormus1's Avatar
Default Serious Help From All ITR peeps
Well I have a problem with the itr. Just rebuilt the motor to JDM spec and it fuel cuts or stutters at 4k rpm and over. Changed both O2 sensors, sparkplug wires, distributor ignition moduel, and external coil. I am stumped and need your help. The other night while driving after I changed all these parts the car just died and wouldn't start. Then in the morrning I went back and it started but struggled to keep running. All responses will be appreciated. Thanks
Old Jul 9, 2009 | 02:24 PM
GUILOTINE's Avatar
Kill Gil
Default Re: Serious Help From All ITR peeps
any cel's?
Old Jul 9, 2009 | 06:19 PM
itr1055's Avatar
Check for a loose ground bolt on top of the thermostat housing. Sounds like exactly what mine did to me.
Old Jul 9, 2009 | 07:24 PM
enormus1's Avatar
No cels at this time
Old Jul 9, 2009 | 10:02 PM
94rs-turbo's Avatar
check the three grounds, n make sure dizzy is all good everything in it
Old Jul 10, 2009 | 06:20 AM
fpvteg0681's Avatar
my car ended up being the cap and rotor for the dizzy
Old Jul 10, 2009 | 08:40 AM
totsie7944's Avatar
Put new plugs in, then swap a dizzy off another R that you know is running properly. Willing to bet my left nut the dizzy is the problem.
Also, did you do any cutting into the wireharness for anything? If so, re-check solder jobs.
Old Jul 10, 2009 | 11:15 AM
Shawn C's Avatar
In The Garage
i'd check the thermostat housing grounds for sure (this is where the ecu grounds at) also maybe the MAP and TPS sensor plugs are swapped?
Old Jul 10, 2009 | 12:03 PM
SoTexDC2's Avatar
Be sure the TPS and MAP sensor plugs aren't reversed. They're the same connector and easy to mix up. My last build did the same thing, and this was my problem.
Old Jul 10, 2009 | 04:01 PM
enormus1's Avatar
Thanks for all the info. Checked the thermostat ground and its on tight. will check the tps and map plugs today
Old Jul 11, 2009 | 09:42 PM
enormus1's Avatar
well the tps and the map sensor is all good. I guess gotta change the distributor. anyone have any other suggestions. anyone also looking for a msd blaster coil only in the car for 1 day when was working. also got a new distributor ignitor moduel bought from acura for $180
cvc1393
Nov 3, 2009 06:14 PM
dansred2000si
Feb 19, 2008 05:24 AM
ITR-965
Sep 17, 2006 11:48 AM
itrdriver1071
Apr 30, 2005 01:42 AM
mR. Vash
Sep 8, 2004 10:50 AM
