sputtering problem!! on b16
alright my car does not do this all the time but usually after a couple minutes of driving it will. when i start it up it drives fine after about fifteen or twenty minutes it will start to sputter and sound like a Subaru but if i hit the gas it breaks loose and works fine but then if i let go and drive it normal it continues to sputter.
my car did the same exact thing. it was the temp sensor not plugged in all the way so check that.. also check you o2 sensor. check your distributor and check your tps sensor.........
93CivicSiSOHC
21
Feb 4, 2005 04:10 AM
