1991 honda civic wont start/no spark and lots of new parts
I have a 1991 honda civic lx and I have replaced the starter, ecu, distributor, wires and spark pulgs. I can get the car to turn over but will not start. I am not getting any spark at all but I have power to the distributor. I have checked for voltage and I am getting it and the distributer will turn. I am so lost can anyone please help me?
for free.
Yeah there are some great sites that show you how to test your main relay (google it) if you want to check them out before you get a new one.
The easiest way (not always 100% telling) is take your main relay out (box about the size of a pack of smokes near the fusebox by your left knee), then take the plastic cover off. Once the cover is off look along the circut board for any weak connections or any burn marks, if its just a poor solder point you can resolder it easily. Burnouts can be a little more work.
yeah free! 5 finger discount..or just do what my friend did to check if it was that..bang it on the floor and if it starts after that your relay is busted..
I have the same issue!!! sorry to jack this thread but im new and cant post my own
I have a crx with a b16a replaced the dizzy and the main relay and it still wont turn on just crank...?
the dizzy has no spark to it even though its brand new..
tried it on another car and dizzy does work what can it be?
ecu?
any help is appreciated thanks in advance
ecu?
ecu?
ecu?
what should I check for the wires going to the dizzy? can you be more specific?
thanks
I had a friend with a similar problem. Turn out to be the thermostat housing ground wire broke off the ring terminal.
06turbocivic18
Oct 13, 2009 10:04 AM
hondadx92
Aug 12, 2009 07:04 PM
