EM1 leaking grease near axle boot clamp HELP
Old Jul 8, 2009 | 01:21 PM
taimysho0's Avatar
Default EM1 leaking grease near axle boot clamp HELP
hello, i was changing my oil and noticed that there was some leakage of grease from the right front axle, it looks like its coming out of where the clamp is at, near the axle boot. i checked the other side and it is dry as a whistle. i noticed beforehand that my car was veering to the right, i already got alignment and it still veered to the right. would this be causing it? axle boot is not torn. would i just need to take off the clamp and put a new one in? or is my problem worse
Old Jul 8, 2009 | 01:27 PM
iliv2xlr8's Avatar
Default Re: EM1 leaking grease near axle boot clamp HELP
A wearing axle will not cause alignment issues. Fixing the boot would likely be more trouble than its worth. I suggest letting it go until the axle needs replaced or just replacing it now if you like.
GL
Old Jul 8, 2009 | 01:29 PM
EL Vap133's Avatar
Might as well replace both axles in case driving it without the axle grease caused any hidden damage.
lerks909
Jul 25, 2014 10:25 AM
ShinotakuX
26
Oct 18, 2008 06:38 PM
Keewun
Dec 20, 2004 04:21 AM
sinfulDB1
Dec 2, 2003 10:53 AM
hadookn
Feb 6, 2002 12:19 PM
