b18c1 intermittent oil leak
1997 civic with a B18C1 swap. all stock. was racing the car on a circle track, after the lap, opened the hood and found oil sprayed all over the driver side engine bay by the mount and power steering resevour. it is clearly engine oil. not p/s fluid or anythign else. no visible signs of where the oil came from and the there is no actual leak....no dripping seeping or leaking while car is on or off.... inside timing cover ( what i can see) looks clean along with the cam sprockets and timing belt.
no holes in the block, engine still runs perfect.
any ideas anyone?
any ideas anyone?
ill get a picture up tonight.... i dont think it came from anything udner the timin cover, i have full timing cover plastics installed and this splashing of oil looks like it couldnt have come from there since theres no holes for it to come through from, also all valve cover hardware including about 4 month old gasket is there
so it ended up being the fluid inside the OEM driver side mount... the mount busted and squirted the fluid all over the place....anyone have an aftermarket they can sell me?
rotaryjunky
Nov 29, 2017 03:15 AM
Civic44
20
Aug 16, 2003 05:03 PM
