running 96' d16y7 civic obd1?
Old Jul 7, 2009 | 07:37 PM
wfocrx's Avatar
Default running 96' d16y7 civic obd1?
Hey, I just got a 97' civic dx. It has a healthy motor and I was thinking about throwing a turbo on it and tuning with crome. Do I just need an obd2a to obd1 harness and run an obd1 ecu? what if I want to change out to a y8 or aftermarket IM+TB?
Old Jul 7, 2009 | 10:06 PM
Ukrainamese's Avatar
Default Re: running 96' d16y7 civic obd1?
Yes, you'll need an obd2a to obd1 conversion harness to run a obd1 ecu. Also to run obd1, you'll need the intake manifold from the Y8 5-speed, also the throttle body, but you can also use the b16 throttle body as well, but the IM from the Y8 is important because you need to run a 2-wire iacv, instead of a 3-wire iacv, which all y7's, and all auto y8's have. Aftermarket is also an option, but using a 5-speed Y8 intake and TB is the easiest route to go.
OBD1 - must use 2-wire IACV! 3-wire IACV will not work.
Here are some links to help you:
http://technet.ff-squad.com/
These links below are for OBD2B! If you're OBD2A, use the link above and go to the correct links under 'ECU & Wiring Tech'.
Remember: 96-98=OBD2A; 99-00=OBD2B
http://technet.ff-squad.com/wiring.obd2b.htm
http://www.ff-squad.com/tech/wiring/wiring.99-01.jpg (3-wire to 2-wire IACV)
http://www.ff-squad.com/tech/wiring/...-01_b-plug.jpg (Don't forget to do this, or it won't run; at least it wouldn't with me)
http://www.ff-squad.com/tech/wiring/...in_removal.jpg
JAYSCRX420
Nov 30, 2018 06:21 AM
Canadian_EF
Sep 21, 2010 08:29 AM
b18integraboy
Sep 17, 2009 06:27 PM
93plumvtec
Mar 26, 2008 06:18 PM
inh
Jul 30, 2006 06:38 PM
