list of parts for turbo, am i missing anything?
Old Jul 7, 2009 | 03:45 PM
Honda4life777's Avatar
Default list of parts for turbo, am i missing anything?
I think I got everything I need to turbo my del. Can you look over this list of parts i ordered and tell me if there is something I am missing.
t3/t4e 50/.63 stg3 5 bolt garrett turbo w/gaskets and flange
turbo manifold (blox) w/gaskets
3" downpipe
wastegate (tial 38mm) + dump tube
intercooler + 2.5" piping
fuel pump (walbro)
injectors (440cc precision)
chipped p28 ecu
datalog cable
oil catch can + mini air breather
slim fan (12")
turbo timer
type r crank pully
msd ss coil
jun flywheel
clutch masters clutch
limited slip diff
adjustable cam gears
rs blowoff valve
boost controller
wideband gauge/sensor
boost gauge
Old Jul 7, 2009 | 04:23 PM
1DayIllBFast's Avatar
Default Re: list of parts for turbo, am i missing anything?
oil return/feed lines
Old Jul 7, 2009 | 05:40 PM
jasoncrashtech's Avatar
don't use the ctr pully. b16b motors are balanced differently than b16a.
Old Jul 7, 2009 | 05:51 PM
so type r crank pully wont do good on a b16a3?
Old Jul 7, 2009 | 05:53 PM
got the oil lines.
Old Jul 7, 2009 | 05:59 PM
there is alot of people that tried the ctr pully and ended up rattling apart their oil pumps.
Old Jul 7, 2009 | 06:05 PM
if i were you i'd prob just use stock cam gears also, just to eliminate potential problems. stock works great (and i think you need a degree wheel for adj cams)
Old Jul 7, 2009 | 11:41 PM
project dc2's Avatar
turbo timer
type r crank pully
msd ss coil
jun flywheel
fairly useless/ hazzard/ waste of money items listed above
Old Jul 8, 2009 | 10:04 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Originally Posted by project dc2
turbo timer
type r crank pully
msd ss coil
jun flywheel
i'm with you on everything else, but the turbo timer?
Old Jul 8, 2009 | 10:05 AM
if you have an alarm its pretty difficult to get the turbo timer to work
in the past 3 years i havent used a turbo timer in any of my cars.
i drive it.. and i park it i dont let my car sit there and cool down unless i been really ripping on it
Old Jul 8, 2009 | 10:12 AM
kyden's Avatar
i use the turbo timer function on my alarm. its nice when you're running late for an occasion!
Old Jul 8, 2009 | 01:55 PM
i had a timer on my last boosted teg. It worked fine. I just assumed that it is kinda important to let the oil cool out before cutting power. I got one for 30 bones so I am going to use it anyway.
Old Jul 8, 2009 | 01:57 PM
And I thought that the cam gears were useful to tune out overlap. How could they be a hazzard/useless/waste of money if most of the really tuned setups I see have them?
Old Jul 8, 2009 | 02:27 PM
omgwtfbbq's Avatar
speaking of a tune...I'm hoping you get one immediately and don't rely on that basemap.
Just a suggestion, if you already didn't plan it. Have fun, sounds like a good setup
Old Jul 8, 2009 | 02:38 PM
Poootie's Avatar
i don't have any of the "hazzard/useless/waste" parts. And i don't have an issue. I also have stock camgears. I had AEM and the bolts came loose and skipped timeing on my last set up.
Old Jul 8, 2009 | 05:16 PM
it depends on how you drive. if your pushing your car let it cool, but if your just puttn' around town driving there shouldn't be a reason to worry
Old Jul 8, 2009 | 06:06 PM
good on a setup that flows and doenst have a lot of backpressure
cast style manifold ? u got a lot of backpressure anyways with that setup
Old Jul 9, 2009 | 05:28 PM
Silver_DC4's Avatar
looks like your on the right track, good luck
John Ackerson
Feb 10, 2015 05:13 PM
brandnew07z
Dec 14, 2008 11:39 AM
AL ASPIRATED
May 19, 2004 06:34 PM
Tru Dynamix
Mar 2, 2003 09:41 PM
hb_racer
Aug 7, 2002 03:07 PM
