Hondata s200 Base Map Questions
Old Jul 7, 2009 | 02:40 PM
092eg6's Avatar
Default Hondata s200 Base Map Questions
hi, just got a b20v set-up, need a good hondata s200 base map to run this sucka.
engine:
B16 head
P72 cams
b16a2 manifold with stock TB
stock injectors
JDM Type r header
Stock b20b block
4.40 ITR trans
ACT 6 puck clutch
engine management:
chipped P72 w/ Hondata s200
you can email it to me song_linda83@yahoo.com
Old Jul 7, 2009 | 03:08 PM
95 integra's Avatar
Default re: Hondata s200 Base Map Questions
Seriously? You're gonna trust your engine to someone that will likely email you a base map for a civic?
Old Jul 7, 2009 | 03:12 PM
b20vtech's Avatar
lol
Old Jul 9, 2009 | 11:34 AM
092eg6's Avatar
good question! but it wont hurt to try.
Old Jul 9, 2009 | 07:20 PM
jdm_sir2's Avatar
Dude call the guys up at modacar they can send you a chip for ur ECU so you can run ur B20Vtec temporarily until u get a chance to get it tuned..... They're quoted me 20bucks shipped for my set up which i'll be taking it to them for a dyno turn later this month!!
Your set up it's pretty stock so you should be good with it!
on mine i'm running bigger injector, higher compression, cams and so on and i trust them!
Old Jan 9, 2010 | 10:24 AM
em1effekt's Avatar
how cAN i get one of these? i need one so i can run it temp meanwhile i get it tuned
Old Jan 9, 2010 | 11:48 AM
00Red_SiR's Avatar
All Motor Mentor
It wil if you end up with a bad or incorrect basemap. There are plenty of people on this board like MTBER, Churches, Xenocron and a whole host of others that can provide you with a decent map for very little money. Not worth cheaping out on.
Old Mar 25, 2011 | 11:32 PM
408EJ1's Avatar
anybody still make base maps need one till i get a tune
Old Mar 26, 2011 | 05:35 AM
00Red_SiR's Avatar
All Motor Mentor
If you took the time to read the thread above you, you would have seen me answer your question and not have to bump a year old thread...
Old Mar 19, 2017 | 04:52 PM
michalski410's Avatar
this is my datalog now this is weird the injectors are cutting out at low rpm do you guys think my injectors are bad they ohm tested the they were all 12.9 across the board I'm confused why when I lighty rev it goes to 2k then drops to 1k then goes to 2k then back to 1k now if I give heavy throttle the car revs just fine then some it dies tell me what you see thank.you guys
Old Mar 19, 2017 | 08:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It appears that your TPS is not calibrated properly... the entire time you are experiencing the issue you describe, the logs you have posted show what appears to be a TPS value of zero. Also check your injector recovery rpm.
Founder
K Series
Jan 30, 2014 11:20 AM
crxb16a90
Engine Management and Tuning
Aug 10, 2009 08:13 AM
ITR9788
Jun 9, 2004 02:14 PM
queez
Dec 27, 2003 07:24 AM
TurBoTeG
Jul 6, 2002 12:30 PM
