b16 swap into a 98 ek hatch exhaust problem
Old Jul 7, 2009 | 10:49 AM
toyotaninja's Avatar
Default b16 swap into a 98 ek hatch exhaust problem
what ddo i need to do to get a catback exhaust for an ek hatch to mate up to a b16? what exhuast would be the best for this application and are their any swap parts that would make this a clean job with out having to do any custom welding? I have one last question... will a gsr ecu work with a b16 properly or would i be better of to switch to a b16 ecu?
Old Jul 7, 2009 | 12:38 PM
supra-n-civic's Avatar
Default Re: b16 swap into a 98 ek hatch exhaust problem
b16 ecu gsr is mapped differently also its going to be much more cost effective to just have the custom welding done if there even is any to be done im not sure unless you want a custom exhaust
Old Jul 7, 2009 | 12:45 PM
geneeunit's Avatar
well on my hatch, im using the exhaust manifold(header) from a 00' si, mid pipe from a 99' ex, and my 96' dx hatch axle back.
Old Jul 14, 2009 | 06:39 PM
how much longer is a b16 header vs. a d series header on a 98 civic cx ... i am at a loss as to what i should do. i like both the apexi ws2 exhaust and the spoon n1 axle back exhaust. I tried to find a civic type r mid pipe with no luck. any help would be greatly appreciated.
Old Jul 14, 2009 | 07:28 PM
goldfinger93030's Avatar
im using my catback from my d series on my b16 swap i love it its pretty much a straight pipe cuz there is no room for a cat but if you dont care about that it should match up perfectly
Old Jul 14, 2009 | 08:04 PM
What type of exhaust do you have and would there be enough room to weld a cat into your catback pipe ?
Old Jul 14, 2009 | 09:23 PM
ek4_b16a's Avatar
You just pretty much get a shop to cut and weld a cat onto your exhaust. Just get a test pipe and bolt it on. Mines straight piped. Gl
Old Jul 30, 2009 | 07:20 PM
is there a difference between a civic 98 civic cx exhaust and a 98 civic dx exhaust and will the 98 civic hatch apexi world sport 2 exhaust fit up to a b16a2 ? thank you for the help
Old Aug 10, 2009 | 08:14 PM
ok now i have the exhaust but it is hitting my shift linkage because i think its the d series linkage what linage works in a 98 cx hatch with a b16
Old Aug 10, 2009 | 08:39 PM
bmoua's Avatar
You should be using a b-series shift linkage, not a orig. d-series.
Old Aug 11, 2009 | 07:39 AM
honda1234567's Avatar
use b-series shift linkage is the right way
_____________________________________
$29 auto insurance for student ages 16-24
@ http://www.localdiscountautoinsurance.com/
I guarantee this will help you save a lot of money.
davidofazrael
Jul 16, 2010 05:19 PM
bibong
May 23, 2010 11:49 AM
CRX30436
Sep 15, 2007 03:23 PM
LSVTEC408
Dec 15, 2003 09:56 PM
