Car died and won't start?
Well today I took my car out just to rip around a little bit already knowing it was running really rich because I never took out the Walbros pump. Lazyness. Started a little hard. I cruised over to my bro's house quick and let it idle outside for like 10-15 minutes. Got in it threw it in reverse and I noticed it was missing. 1 gear it missed a little to till i got higher in the rpms. Died when I got it into second and I couldn't get it started again. Took out the spark plugs. Very black. Cleaned em up still nothing. Anyone got any ideas.
Do you hear the low humming noise of the fuel pump priming for 2 seconds when the key is turned to ON(II)?
Click here to learn how to check for spark.
that means that your fuel pump is getting power, and its cycling on. check for spark. use a spark plug tester, wire it in series between the plug and the plug wire, and crank the motor to see if your getting spark. Hope this helps a little
tpeter91
Oct 25, 2010 06:33 PM
supermario680
Sep 26, 2008 04:14 PM
adip315
Jul 4, 2007 07:21 AM
