Antenna block off
Old Jul 5, 2009 | 07:15 PM
bmwpride's Avatar
Default Antenna block off
hey so i bought the 4dr from my buddy, he had purchased an eg antenna block off so i went to install it and it didnt seem to fit right is there a different one for the 4drs or is there a special way to install
Old Jul 5, 2009 | 07:42 PM
ej1love's Avatar
Default Re: Antenna block off
how didnt it fit right? like the screw holes didnt match up?
Old Jul 5, 2009 | 07:49 PM
ballisticej1's Avatar
lol there should be 2 screws you use and the rubber thing for a gasket kinda thing
Old Jul 5, 2009 | 07:52 PM
ej1love's Avatar
yea...
Old Jul 5, 2009 | 08:19 PM
bmwpride's Avatar
the holes didnt match up, one did and the other didnt. and when i went to align it with the other hole the same happened to the other side?
Old Jul 5, 2009 | 09:53 PM
thumper64's Avatar
There's one for the EG, one for the Del Sol and I think maybe one for the EK?
You should have part number 39152-SR3-A00
Old Jul 5, 2009 | 11:00 PM
^XpLiCiTxX^'s Avatar
Originally Posted by ej1love
yea...
yea but to get to this point is a straight motherf*****.
You have to remove the antenna completely as a unit then use the rubber gasket under the block off plate.
Just did it, so I know.
Old Jul 5, 2009 | 11:17 PM
trying2makeit's Avatar
the eg/ek are the same but the delsol's are different i think.
Old Jul 5, 2009 | 11:45 PM
Korean99EK's Avatar
i don't see how it will not fit. eg and ek's are the same, hatch, coupe or 4 door pimpin.
Old Jul 6, 2009 | 04:23 PM
bmwpride's Avatar
thats what i have and its seems different, i might just have to figure a way out to make it line up. Not sure how thats going to work
Old Jul 6, 2009 | 04:38 PM
get pics
Old Jul 6, 2009 | 09:34 PM
bmwpride's Avatar
ok well it turns out that i have the right part but the previous owner fixed the rust that was happening under the antenna and put a different antenna on it so im going to have to drill and tap it in order for it to work, god this is going to suck!
Old Jul 6, 2009 | 10:43 PM
Korean99EK's Avatar
best of luck man
Old Jul 6, 2009 | 11:25 PM
jdmek_04's Avatar
Have you thought of going to a junkyard, find the same model/year Honda as yours, take the antenna off that one, replace it, and then see where your stand point is? For a used antenna unit that's not going to cost more than $10-$20, you might as well use that small portion of money and then see.
Bet you it'll work
Old Jul 8, 2009 | 07:41 PM
bmwpride's Avatar
its not about the antenna its about the block off plate that im going to be installing. Ill see what happens with this
Leady
Jun 1, 2013 05:05 PM
x_tc-Dae
Honda Fit
Dec 29, 2006 11:37 AM
ROK801
Sep 19, 2005 10:05 AM
EJ8 GSR-T
26
Apr 20, 2005 09:45 PM
KOTSEMOTO
Nov 3, 2002 09:32 PM
