98 integra camber fit 93 civic? tires wobble?
Old Jul 5, 2009 | 01:46 PM
lazyxmofo's Avatar
Default 98 integra camber fit 93 civic? tires wobble?
does anyone know if a 98 integra camber would fit a 93 civic? my passenger tire is wobbling real bad. i was wondering would the camber be doing this?
Old Jul 5, 2009 | 02:10 PM
98civdx's Avatar
Master Detailer
Default Re: 98 integra camber fit 93 civic? tires wobble?
um no, camber would not cause the tires to wobble.
check the tourqe, it lugs could be loose, cause the wheel to wobble.
or you need a new wheel bearing.
Old Jul 5, 2009 | 02:27 PM
ej1love's Avatar
ALL 94-01 integra suspension is compatable with 92-95 civics. maybe u need tires balanced?
Old Jul 5, 2009 | 10:16 PM
lazyxmofo's Avatar
oh really? heres what happend. my friend forgot to tight the lug nut when he switched the tires then we drove and it just came loose and the car dropped. now when i try to drive it wobbles. what can be wrong with the suspension?
Old Jul 5, 2009 | 10:55 PM
98civdx's Avatar
Master Detailer
have you even looked under the car?
is the rotor messed up? bend lca? wheel bent?
theres alot of things that can cause that,
look under the car and tell us what you see, wiggle the wheel back and forth
Old Jul 14, 2009 | 10:01 PM
lazyxmofo's Avatar
yeah i just had the chance to do it. i wiggled the wheel back and fourth..it wobbles. what should cause this to happen? everything looks fine inside though
Old Jul 14, 2009 | 10:51 PM
96DelSol's Avatar
Might have bent the lca.
Put it on stands and turn the car on and just let go off the brakes and inspect under.
Old Jul 15, 2009 | 02:32 AM
roger93si's Avatar
the whole hub might be bent also from all the weight falling on it.
Old Jul 23, 2009 | 10:05 PM
lazyxmofo's Avatar
so i figured out why it was wobbling. now the part when i jack up my car, i can wiggle the wheel left to right. is it suppose to be like this? i thought it was suppose to be stiff?
Old Aug 5, 2009 | 05:29 PM
verycleanhatch's Avatar
sounds like you ball joints.
Old Aug 5, 2009 | 05:32 PM
sp00ledbseries's Avatar
left to right is tie rods or wheel bearing. up and down is ball joints make sure you didnt bend anything. Take some measurements from different places on the other side and make sure they are the same
CallMeKing
Apr 20, 2012 10:51 AM
Dragsparks
24
Dec 17, 2009 05:35 PM
ware
Suspension & Brakes
10
Apr 7, 2007 10:44 AM
rasta420
Sep 20, 2005 08:57 AM
Bklyn TSi
Nov 30, 2001 08:37 AM
