Evap wire. B16a going into 97 civic ex auto.
Old Jul 4, 2009 | 12:05 PM
97booger's Avatar
Default Evap wire. B16a going into 97 civic ex auto.
This is my first swap. I have a complete swap out of a 00 si. I notice when i took out the automatic d16 that it had an extra senser for the evap canistar. I have searched the forum but no one has followed up with a solution of either using the si harness and ecu or just going with the 96 98 civic harness. Im not worried bout emissions but this will be my daily and i want a reliable setup that without cel popping up. Oh and the si harness doesnt have the extra plug for the driver side harness by the clutch reservoir. Any help i would appreciate.
Old Jul 5, 2009 | 03:20 PM
97booger's Avatar
Default Re: Evap wire. B16a going into 97 civic ex auto.
Does anyone know if the si ecu and harness will work with the 96 00 civc.
Old Jul 5, 2009 | 03:39 PM
94EG8's Avatar
Seagull Management
You must use a '96 - '98 harness in a '96 - '98 civic and a '99 - '00 harness in a '99 - '00 civic unless you also swap the corresponding interior underdash harness as well.
Old Jul 5, 2009 | 04:28 PM
97booger's Avatar
Thanks does it matter if its an auto harness and what wires do i need to extend and modify to work with the engine ?
Old Jul 5, 2009 | 04:34 PM
94EG8's Avatar
Seagull Management
Sorta, if its an EX automatic harness you will have to perform the "IACV fix" shown below
Possibly the IAT sensor, can't think of anything else off hand, basically anything that doesn't reach to where it needs to go. The best thing to do is test fit the engine harness with the engine on the floor or on an engine stand to see what needs to be modified.
Old Jul 5, 2009 | 04:52 PM
97booger's Avatar
Thanks alot 94EG8. I will let you guys know how it turns out im doing this by myself and just trying to do it right the first time around.
mr.k24
Jun 6, 2009 06:22 PM
EJ8Omar
17
Aug 15, 2006 12:04 PM
geebs
Jul 30, 2006 01:21 PM
oneforce
Apr 11, 2006 02:46 AM
another civic
Oct 30, 2002 04:43 PM
