Missfire? Hesitation?
Basically I have a JDM GSR, with a Garrett T3/T04E .60/.63. Car is tuned fairly safe with 11.6ish AFR's at WOT. At roughly 6000rpm, the car starts to "miss". It hesitates, slightly bogs, and missfires. I'm using NGK BKR7E's, gapped to .025. After roughly 6-8 passes at the track, and a week of driving it starts happening, am I killing plugs or, or cold it be somthing else contributing to the problem?
EDIT: I forgot to mention, I can do a pull at 75% throttle, building 11 psi and it doesnt missfire. Soon as I go WOT is when it happens.
I had a similar misfiring problem twice. The first time it was a loose wire connected to the ignition control module. The second time it happened, I pulled the plugs and #3 cylinder plug was somehow gaped at .30 and the rest where .02, so I put it back to .02 and the car ran perfect.
Hope that helps.
Hope that helps.
bumbaiulearn
11
Mar 28, 2006 12:49 AM
