how to adjust coilover
Old Aug 22, 2002 | 12:10 AM
JDM-FREAK's Avatar
Default how to adjust coilover
hi, i just ordered GROUND CONTROL and i really like to know how to adjust coilovers. i heard that you have to put it on first and adjust them.. but with left-front and right-front.. how do you exactly know how much you drop?.. can someone teach me how?.. sorry.. if this sounds stupid. i don't know much about coilovers..thanks for your time~
Old Aug 22, 2002 | 12:21 AM
Dodger2940's Avatar
Default Re: how to adjust coilover (takumi_79)
IF I am not mistaken GC has a key that you use to loosen a bolt. After it is loose you can turn the sleave to raise or drop your car. I am not sure how to tell the drop, but make you that the two sides are at the same hieght. I think you should put them on first.
Old Aug 22, 2002 | 04:01 PM
JDM-FREAK's Avatar
Default Re: how to adjust coilover (Dodger2940)
thanks for the help.. anyone else ???
Old Aug 22, 2002 | 04:21 PM
gsrvx's Avatar
New User
yup..u loosen the screw with the provided allen wrench...and twist the collar.
-Rod
Old Aug 22, 2002 | 04:42 PM
96 SOHC VTEC's Avatar
Default Re: how to adjust coilover (RK)
You can look at the coils and the ring that you are turning to see how much you have dropped it. However, I found that one side needed to be turned more than the other in order to get an equal drop. Really, when I adjust mine, I have to adjust it and look at where it sits to get an idea of the ride height.
Old Aug 22, 2002 | 06:11 PM
civicrtype's Avatar
Default Re: how to adjust coilover (96 SOHC VTEC)
ya just make sure that you on a flat surface. Then you can measure from the middle of the bottom of the fenderwell to the ground if you want to be more precise.
Old Aug 22, 2002 | 10:52 PM
JDM-FREAK's Avatar
Default Re: how to adjust coilover (civicrtype)
thanks a lot guyz !!!
Old Aug 22, 2002 | 11:09 PM
slammed_93_hatch's Avatar
no need to tighten the alan at all its not needed and over kill i have had GC for 2 years put alot of miles on all the cars and never tighted the alan and nothin happens
thebluecrx
Feb 7, 2011 02:38 PM
Project SSAP1
Honda S2000
17
Sep 14, 2005 06:45 AM
white4doorsi
Feb 15, 2005 07:19 PM
Ti3d in
Suspension & Brakes
12
Jan 24, 2005 06:26 AM
Understeer
Oct 28, 2003 10:25 AM
