how to adjust coilover
hi, i just ordered GROUND CONTROL and i really like to know how to adjust coilovers. i heard that you have to put it on first and adjust them.. but with left-front and right-front.. how do you exactly know how much you drop?.. can someone teach me how?.. sorry.. if this sounds stupid. i don't know much about coilovers..thanks for your time~
Re: how to adjust coilover (takumi_79)
IF I am not mistaken GC has a key that you use to loosen a bolt. After it is loose you can turn the sleave to raise or drop your car. I am not sure how to tell the drop, but make you that the two sides are at the same hieght. I think you should put them on first.
Re: how to adjust coilover (RK)
You can look at the coils and the ring that you are turning to see how much you have dropped it. However, I found that one side needed to be turned more than the other in order to get an equal drop. Really, when I adjust mine, I have to adjust it and look at where it sits to get an idea of the ride height.
Re: how to adjust coilover (96 SOHC VTEC)
ya just make sure that you on a flat surface. Then you can measure from the middle of the bottom of the fenderwell to the ground if you want to be more precise.
no need to tighten the alan at all its not needed and over kill i have had GC for 2 years put alot of miles on all the cars and never tighted the alan and nothin happens
white4doorsi
02-15-2005 07:19 PM
Ti3d in
Suspension & Brakes
12
01-24-2005 06:26 AM
