98 Ex accord w/ usdm h22a4 install
Old Jul 3, 2009 | 01:47 PM
H22_aCCoRd_07's Avatar
Default 98 Ex accord w/ usdm h22a4 install
Trying to figure out what dizzy to use. The car is equipped with a 4 wire plug(interal coil) and the motor is out of a 99 and came w/ 2 plugs(external coil)
The problem is not converting from external to internal, its how do plug up the dizzy? How do how convert the harness? Or do i need another dizzy from another car
Old Jul 5, 2009 | 07:22 PM
nus_dogg's Avatar
Default Re: 98 Ex accord w/ usdm h22a4 install
Probably get another dizzy.
Old Jul 6, 2009 | 09:32 AM
from what car?
Old Jul 7, 2009 | 01:01 AM
somebody has done this swap before... come on peeps
Old Jul 7, 2009 | 01:52 AM
gianinline's Avatar
Check the FAQ.
I think it's possible for you keep the h22 distributor and only have to modify the wiring.
http://www.honda-acura.net/forums/do...swap-faqs.html
Old Jul 8, 2009 | 01:44 AM
Originally Posted by gianinline
Check the FAQ.
Ive check that thread out a couple days ago... besides all that link says is.....
"6TH GEN TECH
There isnt much info on 6TH gen swaps. Aperantly the timing belt side mount is an issue as
well as the immobilizer "
........so yeah still no luck
Old Jul 12, 2009 | 08:35 PM
still need help people
Old Jul 13, 2009 | 08:40 AM
H22PwrdInspire's Avatar
Hopefully this will help you because this is what I did when I swapped my H22 into a 92 Accord.
Internal/External Coil Issues:
If your car came equipped with an internal coil then the JDM H22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wires together. The Black/White wire is useless, don’t worry about it. If you dont want to cut the plug off and splice, jam a 30amp fuse into the end of the plug, making the connection between the two wires.
If your car is external coil and you wish to maintain the external coil you will need to open the JDM dizzy, remove the internal coil. Run the wire from the igniter that used to go to the internal coil out of the distributor and plug it into the blank spot on the distributor’s plug. That’s it. Use the 93-95 Prelude Vtec’s Distributor cap and rotor that you can pick-up and your local dealer or auto parts.
What caps to use:
Internal coil – CB7 internal coil cap/rotor or 00 Civic SI cap/rotor.
External coil – 93-95 Prelude Vtec cap/rotor.
BrothaSit
Jan 5, 2011 06:19 PM
crxh22a4
Mar 28, 2008 11:11 AM
jellyroll
Apr 17, 2006 03:47 PM
Vtecless212
Jul 16, 2003 07:59 AM
