Interesting Electrical Issue
Ok, so this issue is pretty plain and simple.....just not for me. LOL I was wondering if anyone else has experienced this, and if so, how they corrected the issue.
-When I press my Brake pedal with the headlights OFF, the instrument cluster lights up.
-When I turn on the headlights, the third brake light stays on consistently. The lights still dim/brighten when the brakes are applied/released.
I recently swapped a B16 into my EF, but the only wiring I messed with was of course, the engine harness and ECU harness. I never messed with the dash harness, except for when I installed a civic cluster with a tach.
Any ideas? All help is appreciated.
Honda electrical systems are pretty reliable. I wouldn't chase anything other than wiring you have done yourself.
That being said, I'm not sure how much anyone on here can really help you... It's all electrical troubleshooting from here on.
If it was me, I'd unplug one plug at a time (or even the whole engine harness) to try and isolate where the issue is coming from...
a similar problem hapend to me when i pressed my brakes my seatbelt light would flash and my tailights shut off completely. i just ran a new wire from the fuse box to the brake swich and off the load side of the swich to my brake light power at the back of the car and hooked it up there and disconected the old wire heading back completely. it took like 30 miniutes or you could spend hours looking for where you pinched the harness somewhere and two wires are touching.
Thanks for the input everyone....it's just awkward, as I never messed with anything behind the dash other than the ECU harness. Now, however, she seems to be doing fine.
Wierd.
Wierd.
motoman32002
Nov 17, 2011 05:07 AM
ninetyfourgsr
Feb 4, 2004 01:12 PM
Mr. Vapor
Dec 7, 2002 12:50 AM
