Buying used turbo's
Old Aug 21, 2002 | 10:19 PM
99ls's Avatar
Default Buying used turbo's
What should I be looking for when buying used turbo's?
Old Aug 21, 2002 | 10:23 PM
CzanSOHC's Avatar
Default Re: Buying used turbo's (99ls)
Ask the seller i a turbo timer was used, check all the hardware and stuff for any defects, make sure the turbine spins freely...**** like that..i'm sure some other people will hve better advice
Old Aug 21, 2002 | 10:35 PM
sutrusu's Avatar
Default Re: Buying used turbo's (CzanSOHC)
main thing:
is there any shaft play! radial or axial! a little radial play is OK, axial is a NO NO
Old Aug 21, 2002 | 10:47 PM
shadowdawn's Avatar
Default Re: Buying used turbo's (sutrusu)
I bought my turbo used and the play is perfect, but unfortantly its leaking a little oil to the point where when I had my intercooler off (3 months after turbo was on and running) there was oil coating the tubing and a little coatin on that side of the intercooler.... but none on the intake side...
Anyone know if seals can be replaced easily by oneself? Or is a turbo rebuild in order sometime down the line?
young geezer
Oct 20, 2010 08:53 PM
boostedteg4dr
Jan 29, 2008 02:11 PM
boostedh22lude1
Oct 8, 2007 06:29 PM
SynTeg
Jul 28, 2004 01:27 AM
