which obd1 ecu?
Old Jul 2, 2009 | 11:58 AM
19REX89's Avatar
Default which obd1 ecu?
hey im going to be doing a dpfi to mpfi swap on my d15b2 and since i want to go turbo down the line im going obd1 too so far i got the manifold, obd1 injectors and the td41u(obd1) dizzy. now my question is what ecu should i get the p05 or the p06?
p.s. i dont plan on going vtec since i will go turbo.
Old Jul 2, 2009 | 12:11 PM
8dxhatchy8's Avatar
Default Re: which obd1 ecu?
p06 will work fine....thats what i used
Old Jul 2, 2009 | 12:12 PM
ek-g6's Avatar
I think the po6 will do, has tunning cappability of a p28, i cant say the same about the po5.
Old Jul 2, 2009 | 12:14 PM
19REX89's Avatar
thanks what about the redline? is it the same on both.
Old Jul 2, 2009 | 12:48 PM
dephtone's Avatar
the p05 is from a CX 92-95 and the p06 is from a DX 92-95. Both ECU's can be converted to VTEC (this is saying you plan on running a vtec head)by replacing the required little circuits on the board when you get into getting it socketed and everything. The p05 runs a little leaner for better fuel economy and the p06 will have a little more power to it.
Either way you can get a basemap for whatever motor you are planning to run and it will have the same capabilities as a p28 if all board modifications are done correctly.
Old Jul 2, 2009 | 12:54 PM
19REX89's Avatar
so p06 it is
swordofdoom
Engine Management and Tuning
19
Jul 27, 2020 08:05 PM
TurbodTegra
Mar 10, 2011 12:46 PM
cmasonrun
Jun 1, 2007 04:56 PM
4EN[sic]
Mar 25, 2007 10:07 AM
importnoodles
Jul 2, 2005 07:52 PM
