Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
NHMS July 7-8th
Old Jul 2, 2009 | 10:32 AM
b16a1eg6's Avatar
Default NHMS July 7-8th
Anyone here going?
Old Jul 12, 2009 | 02:21 PM
b16a1eg6's Avatar
Default Re: NHMS July 7-8th
Here's a vid from day 2 time trial.
http://www.youtube.com/watch?v=6wS82oc2FI8
Criticism or comments welcome. I know I was not heel toeing into some corners and should have shifted rather than hit the rev limiter into some corners.
Any recommendation as to why my brakes were good into turn 1 but soft in 3? I am running hawk blues w/powerslots up front and HPs pads in the rear. New brake fluid Valveoline supersyn.
Old Jul 12, 2009 | 02:49 PM
essex's Avatar
Perhaps you have a bad bearing?
Old Jul 13, 2009 | 07:32 AM
Ryan239's Avatar
You had a great run, very smooth hands. You said at the gas station you are running the stock b16 tranny? Seems like your b18 is making a bunch more power than my b16a cause I'm not getting into 4th going into the bowl or 5th on the straight (I also have the stock b16a tranny). What steering rack is in your car? Seems like you have a much quicker rack than I do as well, I have the stock one that came in my 91 standard, and I am way busier on the wheel than you.
My footage is here:
http://vimeo.com/5532976
Awesome job in the time trials, a 1:22 is smokin' fast! Are you going to the August event?
Old Jul 13, 2009 | 09:42 AM
b16a1eg6's Avatar
Its a CRX SI rack. I wasn't getting onto 5th on the straight. I was between 100-105 before braking at marker #2. Watching your vid shows me where i was braking too early. Also you were in second coming out of the bowl and turn 12.
Old Jul 13, 2009 | 08:29 PM
dirty19's Avatar
Ridin Dirty in Cali
You were smooth through out the course. Being smooth is very important. Shows me you are not over driving. Speed comes with time. If this was your first time on that course pat yourself on the back. Seat time,an open mind, and picking experienced drivers brains will help alot.
There are some parts where you should of downshifted sooner. The rev limiting is never a good thing. Better to go up one and quickly back down than to cause something to quit on you. Your exits from the turns will get better with time as well learning where you can run with a open throttle vs coasting. Keep up the hard work.
Old Jul 14, 2009 | 02:26 PM
Ryan239's Avatar
Yeah I don't know what I was thinking when I thought you were in 5th on the front straight hehe. My DAQ was showing about 103-104 into 1 although the display lags a bit behind, so I won't tell for sure until I download the data onto my laptop. I am not sure if 2nd is doing me favors in 11b or not, but I tried third a bunch in the open track and kept missing my braking points, but I don't know if that was due to the sprinkles getting the track damp or not; I have to review my data logs and see what's best. The bowl definitely needs second as I just don't have the torque to accelerate up the hill in third. In my STI it was a tossup between 3rd and 4th going out of the bowl, but I used 3rd even though I had a ton of torque as it wound up being a tad quicker.
I'm going to stiffen the rear end next event, as my sway bar is set on full soft, and see what happens. The car rotates pretty well, but I still think it pushes too much. This is the first event where the car didn't break, so I finally got some clean laps to figure out the handling. I haven't really changed any settings in 2 years (full stiff on rear konis and about halfway on the fronts) other than alignment. I think I can catch Mick in the E30M3, but I need to find a second to do it.
Old Jul 14, 2009 | 06:20 PM
Lo-Buck EF's Avatar
lookin' good guys
Old Jul 16, 2009 | 08:31 AM
b16a1eg6's Avatar
found this on my memory card.
http://www.youtube.com/watch?v=rGHlvKHNaZ0
Old Jul 17, 2009 | 05:34 AM
Ryan239's Avatar
nice find, thanks!
XViEtBoiX
Honda Civic (2001 - 2005)
Oct 8, 2008 02:11 AM
AamirCWITR
Feb 2, 2007 05:00 AM
skunksol
Jan 31, 2006 09:04 AM
9civic1hatch
Sep 1, 2004 05:53 AM
denieone
Jun 19, 2002 10:50 AM
