doin a dpfi to mpfi swap
Old Jul 2, 2009 | 09:24 AM
JdmRex25's Avatar
Default doin a dpfi to mpfi swap
ok guys....
need a lil help here. im doin a dpfi to mpfi swap on my 88 rex dx and ive acquired most of the parts so far..
1. 91 si engine harness
2. 91 si dizzy
3. 2 91 pm6 ecu's
4. 91 si injector resistor
5. 00 y8 intake manifold w/ all sensors, injectors n fuel rail
now my question is will the y8 manifold work? ive already found the postin on doin the swap and i kno i have to rewire a few things, so that part im clear on, i just havent found a post yet where they swapped in a y8 manifold.
Ne help would be much appreciated
Old Jul 2, 2009 | 10:02 AM
Clipsed's Avatar
Default Re: doin a dpfi to mpfi swap
yes it will work, sensors are different though, and the si engine harness will NOT plug into your car.
Old Jul 2, 2009 | 10:34 AM
JdmRex25's Avatar
ok y wont the harness work it clipped rite into the old spot under the hood?
Old Jul 2, 2009 | 10:43 AM
8dxhatchy8's Avatar
ur rex is an 88? and u said the harness is a 91, i believe "clipsed" means they are NOT compatable.....
Old Jul 2, 2009 | 10:55 AM
JdmRex25's Avatar
ya ive read that n i have to rewire a few things like i said b4 which to me isn a big deal... just time consuming. i was just wanting to kno the extent of puttin in the y8 manifold bc i tryed clipping in the y8 injectors n the clips didnt go on. i just need to kno wut all i gotta redo b4 i get to pissed off n sell the car. j/k
Old Jul 2, 2009 | 11:11 AM
8dxhatchy8's Avatar
yea ur obd0 wire harness wont clip to the odb1-2 injectors
Old Jul 2, 2009 | 06:03 PM
JdmRex25's Avatar
ok so all i need to do is get the obd0 injectors n drop in ?? i picked up all the 91 sensors today from a buddy o mine
Old Jul 2, 2009 | 08:49 PM
crxx's Avatar
NO NEED N SELLIN IT,JUST A LITTLE TIME CONSUMING BUT NOT THAT COMPLICATED.
Old Jul 3, 2009 | 11:43 AM
JdmRex25's Avatar
im not gonna sell rex im just pissed that she's buggin on me again, fried my guauge cluster, stupid *** dpfi sux ***, n im just not gettin answers from myself lol
Old Jul 3, 2009 | 12:31 PM
BiG ChOr!Zo's Avatar
DPFI FTW
Old Jul 3, 2009 | 01:25 PM
Clipsed's Avatar
This is correct, thanks for clearing that up. You can't plug in the 91 Si engine harness into your 88 rex dpfi interior harness. Won't work, dpfi has 3 main plug ins, while mpfi has 4, there are extra wires on mpfi cars, thus why you do wiring when converting... If it were a case of plug and play, you wouldn't have these questions for us...
And no, you don't NEED obd0 injectors, unless you plan on using the injector clips from your 91 si engine harness, THEN you NEED obd0 injectors along with an injector resistor box. If you don't plan on running obd0 injectors then you will need the injector clips for the injectors you have, and you will need to delete your injector resistor box.
Seriously, just use your stock DPFI harness, and add the necessary wires. It's REAL easy, and a LOT less of a headache then trying to do some crazy *** wiring conversions... Been there... Done that... Or you can continue your path of trying to do things yourself and not taking anyone's advice, but I'm just trying to help you out get things right. If you need some injectors, I got some obd0 240cc injectors that I'm going to sell from my spare manifold, they work flawlessly.
Old Jul 3, 2009 | 04:49 PM
KWayRacing's Avatar
Dpfi to Mpfi is so simple. Yes keep the original harness. Si harness is only good for donations. THe Si harness is different in many ways and just can't be used without serious modification. So just add four wires to your existing harness. I have made subharness before to do this. Using the complete y8 manifold with injectors makes the wiring really easy since no resistor box necessary. Since you have both complete harnesses you can make this look really nice and factory like. Either way there is plenty of info out there to make this easy for you. Good Luck
Old Jul 3, 2009 | 06:09 PM
JdmRex25's Avatar
preciate it guys.. im not tryin to be a hrad *** but like i said i had never done this kinda mod b4 so i was tryin to root out all the bs n get it done correctly n "clipse" i never said i wudnt take advice im just stubborn dude/chic... so no ill will there k.
Old Jul 7, 2009 | 01:04 PM
JdmRex25's Avatar
ok guys back here again.... picked up a FULL 91 si wiring harness aka gotta donor car with totaled *** end. so now i shud be good b/c it has everything i need cept a damn radio harness again. so i shud now be good rite???
Old Jul 7, 2009 | 05:26 PM
civic accord honda's Avatar
yeah just strip both cars down remove the whole cars harness and install the whole si one.. wish i would of gone that direction lol would of made things simpler when i do the wire tuck..
also wouldn't of had to repin the ecu harness **** is a pia
Old Jul 7, 2009 | 05:53 PM
JdmRex25's Avatar
lol i was gonna go that route but i cudnt pass up an offer of 300 bux for the who car so i did the smart thing lol
Old Jul 7, 2009 | 08:04 PM
91-hatcherz's Avatar
question? if i just wanna swap my dpfi to mpfi with non-vtec throttle body is it hard cause i am prolly getting a parts car but its not an si model just a dx i belive. so is it hard to swap throttle bodies to my 91civic cx? all have all the stuff to swap off a runnign car so what will i need to make more power with the parts cars motor to mine?
Old Jul 7, 2009 | 08:23 PM
ninety1Dseries's Avatar
if you use everything from an si then does anything to do with v tech get in the way? i am planning on doing this in the future so just want to clear that up. i have a dx so it is the d15b2/non v tech
Old Jul 7, 2009 | 08:36 PM
project:JDM's Avatar
not trying to be a dick but its VTEC and here u go....
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-mpfi-swap-information-639552/
Old Jul 7, 2009 | 08:47 PM
lol i even second guessed myself on it! i thought it was v tec just didnt want to look like an *** but.............
Old Jul 7, 2009 | 11:55 PM
tek44's Avatar
its not hard really if you think about a minute youll get it. http://www.geocities.com/teampimports/fuelinj.html
Ef9_408
Apr 11, 2017 02:41 PM
gwarbmx
Jun 18, 2011 08:23 AM
bronxbomber0215
Mar 11, 2008 10:55 AM
KhialD
Jun 1, 2003 03:07 PM
