If your good with Car Alarms, I need your help/thoughts...
I bought a Honda a year ago from a friend and ended up breaking the car alarm remote when I dropped it. Now, I've tried over and over to program a new remote for the system but it refuses to go into Learn/Program mode so the remotes I bought are useless. Recently I got the idea to switch out the current alarms brain with another one. The currently installed one is an Automate from Directed Electronics and I found a basic Viper alarm (Also from Directed Electronics) at Best Buy. I don't know what exact Automate model it is, the only mark it has is the ID: (EZSDEI437). Would it be possible to switch the brains even though one is Viper and the other is Automate but both are from DEI and leave the current wiring/switches/sensors in the vehicle?
If no one has any suggestions on switching the alarm "brains"...
Is there anyone familiar with DEI alarms?
I can't get my alarm to go into Program/Learn mode at all. I've searched for hours on Google today and yesterday and the farthest I get is the programming guide in this link: http://www.drdetailshop.com/remoteprogram.html
The guide would be great and all, if only my alarm responded in Step 3 insteading of doing nothing like it does now.
Need a model number for the Automate, not all DEI alarms use the same method for transmitter learn routine, some also have programing "lock out" jumpers that must be moved to "learn" position and with others the transmitter learn routine can be locked out with the DEI Bitwriter, [Bitwriter is needed to unlock learn routine] so drop the Automate brain and get a model number. 94
Des.345,711
OK/4I Sticker
Where are these "lock out jumpers" located? On the side of the brain, inside it, or somewhere else?
I took a couple pictures too, so if anyones good with wiring and could help me figure out why it won't go into program mode...
Wire harness, number says HWAXC16B
Pciture of the plugins
Words on the side read:
-Shock Sensor (White 4 Pin)
-Status LED (White 2 Pin)
-VRS Switch (Red 2 Pin)
-Prog. Switch (White 2 Pin)
-Valet Switch (Blue 2 Pin)
-Door Locks (White 3 Pin)
-Greenwire ( (-)Output Lock, (+)Output Unlock)
-Bluewire ( (+)Output Lock, (-)Output Unlock)
Hands kind of in the way but I had to hold it to get the picture...
The words on the bottom upside down read:
12 Pin Primary Harness
-Red/White (-) = Output Channel 2
-Red (+) Input = 12v Power
-Brown (+) Output = Siren
-Yellow (+) Input = Switched Ignition
-Black (-) Input = Chasis Ground
-Violate (+) Input = Door Switch
-Blue (-) Input = Warn/Trigger
-Green (-) Input = Door Switch
-Black/White (-) Output = Domelight Supervision
-White/Blue (-) Output = Channel 3
White (+) Output = Parking Lights
-Orange (-) Output = When Armed
That harness wont be compatible with any DEI alarm, def not Viper, Python, Clifford, Hornet. But you can cut the wires and wire them color for color to the new alarm's harness.
take the short plug out of the white plug and plug your valet into it
That is your programming location. Its a mid 90's dei design. Te unit should enter programming then.
Any idea what the red plug is for?
Ronin Integra8
Audio / Security / Video
Apr 9, 2003 05:09 PM
