Wagovan Trans?
no. sohc tranny on a doch engine... no go.
but strangely enough, you could probably use the awd tranny from a crv. looking from underneath a awd wagon, from the drive shaft back it looks almost the same as a crv.
there will be some fabing to do, but it could work.
go with the b20 crv setup its a little work like the shifter swap and you have to make your own trans mount but it works i have a buddie that did it ill try to get some pics soon
It's more then just a little work. Besides, you don't want to be stuck with the CRV's gumby clutch actuated 4wd system.
FukieneseDragger
Jul 1, 2002 08:02 AM
