how do you take off the climate controll?
Old Aug 21, 2002 | 07:31 PM
ridiculous's Avatar
Default how do you take off the climate controll?
does anyone know how to take off the climate controll without chipping the hell out of it? it looks pretty damn fragile around the edges. do i have to take off the whole dash piece around it? (its a 93 ex, if that matters)
[Modified by ridiculous, 9:32 PM 8/21/2002]
Old Aug 21, 2002 | 09:16 PM
TurboBumblBee's Avatar
Default Re: how do you take off the climate controll? (ridiculous)
slow down bud before you really **** things up.. you gotta remove the radio first and then you will see *i think* 3 skcrews holding it in. remove the screws and the unit will be much easier to remove.. btw, why are you taking it out anyways??
Old Aug 22, 2002 | 08:39 PM
ridiculous's Avatar
ok i will try that, i need it off because i need to replace some bulbs that have burned out, i can acces them from the back i assume, correct? also the bulbs for the switches?? thanx!!
Old Aug 22, 2002 | 08:40 PM
batibot's Avatar
A hammer?....JUst kidding ....Would a repear manual say how?
[Modified by batibot, 5:41 AM 8/23/2002]
Old Aug 22, 2002 | 08:59 PM
skunk2unerz's Avatar
Default Re: how do you take off the climate controll? (batibot)
you have to take the radio out and then the center console (lighter/ash tray part)...under where the center console there is a screw (1) underneath that you have to remove also...then from the back side there are 3 screws then when you take out the climate control you have to be sure to take it out carefully and remove the cable on it ( if its not the automatic ones)...then it should come out.
Old Aug 22, 2002 | 09:01 PM
Default Re: how do you take off the climate controll? (skunk2unerz)
here is a "how to install a climate control" maybe this will show how to take it out...
http://jdmfan.com/technical/cosmetic/jdm_eg-climate/
Old Aug 23, 2002 | 06:31 PM
ridiculous's Avatar
thanx skunk, looks like that will help a lot, i'll try tomarrow, let you know how it went, thanx again!!!
Old Aug 30, 2002 | 10:00 AM
ridiculous's Avatar
almost had it i think, but i cant get the climate controll switches off, they're on pretty damn good!! any suggestions?
Brake_Check
Dec 18, 2013 10:29 AM
simplyrob
Aug 19, 2006 12:23 AM
UNKNOWN_MEMBER
Jan 3, 2006 10:03 AM
deez nuts
Jan 20, 2005 03:30 PM
civic_tuner
Aug 18, 2004 01:59 PM
