how do you take off the climate controll?
does anyone know how to take off the climate controll without chipping the hell out of it? it looks pretty damn fragile around the edges. do i have to take off the whole dash piece around it? (its a 93 ex, if that matters)
[Modified by ridiculous, 9:32 PM 8/21/2002]
Re: how do you take off the climate controll? (ridiculous)
ok i will try that, i need it off because i need to replace some bulbs that have burned out, i can acces them from the back i assume, correct? also the bulbs for the switches?? thanx!!
Re: how do you take off the climate controll? (batibot)
you have to take the radio out and then the center console (lighter/ash tray part)...under where the center console there is a screw (1) underneath that you have to remove also...then from the back side there are 3 screws then when you take out the climate control you have to be sure to take it out carefully and remove the cable on it ( if its not the automatic ones)...then it should come out.
Re: how do you take off the climate controll? (skunk2unerz)
here is a "how to install a climate control" maybe this will show how to take it out...
http://jdmfan.com/technical/cosmetic/jdm_eg-climate/
thanx skunk, looks like that will help a lot, i'll try tomarrow, let you know how it went, thanx again!!!
almost had it i think, but i cant get the climate controll switches off, they're on pretty damn good!! any suggestions?
Brake_Check
12-18-2013 10:29 AM
UNKNOWN_MEMBER
01-03-2006 10:03 AM
deez nuts
01-20-2005 03:30 PM
civic_tuner
08-18-2004 01:59 PM
