Rear Speakers
Ok i am going to put rear speakers in my 91 civic std. Ima make holes on the back panels so the speakers could fit. But where do u people with rear speakers connect the +- wires. Do u tap into the car radio harness, the radio harness i got a pioneer radio. Can someone tell me where i hook the speaker wires to?
no i dont have a cargo cover. I am going to cut a hole in the back side panels and fiberglass around it so it looks nice and neat. I just want to know how u hook up the speakers, where do u hook it up, what wire.
If there are no existing factory speaker wires then you will have to run some from your head unit. I had the same issue in the rear of my lx sedan. Mine wasn't that bad though since the speakers run off the amp i have in the trunk.
I just made my own out of Alpine Speakers, and OEM EF Rear Speaker Grills.
EDIT: Oh sorry you asked how they wired them... Well all Hatchbacks came pre-wired from honda with speaker cables running to the trunk, they should be peeking out of your rear seats.
If not wire them correctly into your headunit, it should say +REAR and -REAR labeled
Purple and green are the wire colors off any aftermarket deck for the rear speakers. The - is the grounds. I believe the green is left but don't quote me on that. Wow we have a bunch of smart people on here today. Lol
If you take out the rear wire covers for where you change your brake lights from, you will see two wires that are not connected to anything. Those are your rear speaker wires, their color should match the same 4 wires coming from the radio harness that is not connected.
all420
Audio / Security / Video
May 30, 2003 04:30 PM
